Please Help Me ?
Old Aug 25, 2013 | 05:31 PM
NewFordUser's Avatar
NewFordUser
Please Help Me ?
I Bought A 1999 Ford F350 V8 7.3 Liter ; And Have Replaced Many Parts Such As Starter , Alternator , Both Cylinoids , CPS Sensor , Glow Plugs , IDM ; And Seem Too Still Be Having Problems With It . It Starts Up Fine With A Shot Of Ether , And Stays On For About 20 Minutes Then Shuts Off And Doesn't Want Too Start Up For About Another 10-20 Minutes Cool Down Time . Please Help Me z Thinking About Scraping Soon .
Old Aug 25, 2013 | 05:43 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Welcome. I would not use ether. It can damage the motor. Do you have a scanner to check for codes?
Old Aug 25, 2013 | 06:25 PM
joeyd61's Avatar
joeyd61
check for fuel?? on the back of the fuel filter there is a drain, open it, turn the key to the run position. Do you get a good stream of fuel? The stream will be on the passenger side of the block. Have you inspected the fuel filter?? do you hear the fuel pump when you turn the key on? Its located on the frame rail under the dr side door. Take the fuel line off the suction side of the fuel pump.Blow air back into the tank. The screens in the tank may be clogged..Do a search here on the hutch/harpoon mod..
WELCOME TO FTE !!
Old Aug 25, 2013 | 06:50 PM
carltonwebb's Avatar
carltonwebb
Did u replace the Glow plug relay too? When it cuts off, does it wind down slowly or does it shut off instantly?
Those have steel tanks and it could be trash in the tank clogging the fuel screens. After it sit for 20 mins, it floats away and will crank again until the next time.
Old Aug 25, 2013 | 06:59 PM
NewFordUser
Do Not Have Any Type Of Analyzer . And Will Do That Right Now . And Actually No I Haven't Changed The Glow Plug Relay .
Old Aug 25, 2013 | 07:22 PM
dn29626's Avatar
dn29626
This sounds like a combination of glow plug and a clog in the fuel system issue(s). (As the other guys have already said)
Old Aug 25, 2013 | 07:51 PM
NewFordUser
Checked Fuel Pump And Lines , Pumping Diesel Through With A Good Strong Stream . Was Looking At Gauges While I Was Cranking And Oil Pressure Stays On Low For A Bit Then When It Raises Too A Higher Oil Pressure It Cranks Over And Sonetimes Starts
Old Aug 25, 2013 | 07:57 PM
sand_fiend's Avatar
sand_fiend
YOU SHOULD NOT USE ETHER.... it can cause a diesel motor to run away !!!
also it could be a IPR going bad.
a bad IPR will let the truck stall after it gets warm.
Did you try, unplugging the ICP ? it is the censor on the front of the driver side head. unplug it and try to start it. unplugging it will set the pcm to the default fuel pressure setting..
The ICP can go bad also because they start to leak oil in to the electrical plug..
Old Aug 25, 2013 | 08:05 PM
NewFordUser
Unplugged It And Cranked But No Start .
Old Aug 25, 2013 | 08:20 PM
NewFordUser
Turned It On And I Can Keep It On Pushing The Pedal A Little Bit But As Soon As I Let It Go Down Too Idle It Shuts Off .
Old Aug 25, 2013 | 09:31 PM
Tailgate77478's Avatar
Tailgate77478
Have you checked the tinnerman nut on the IPR? That can cause all sorts of weird problems...especially wanting do die at idle. Could also be a bad CPS. Could also be a broken pickup foot in the tank...is your fuel level below 1/4 tank when this happens?
There are so many things that *could* be wrong. Have you pulled your fuel bowl filter and looked at the bottom of the bowl? It could be clogged up with a bunch of junk in the bottom of the bowl. It could also be a sticky Fuel Pressure Regulator (FPR).
As mentioned, you need to get this hooked up to AE and diagnose it better. Don't get rid of a great truck that might be suffering from poor maintenance and might be fixable for relatively low dollars. Post where you are located, and maybe one of "The Brotherhood" with AE lives close by and they can come help troubleshoot for you...
Old Aug 25, 2013 | 09:55 PM
Pitcrw6's Avatar
Pitcrw6
Im guessing the IPR needs cleaned than try again.
Edit: stupid phone spelling the words out & me not looking what I wrote before I post.
Old Aug 25, 2013 | 10:00 PM
Pitcrw6's Avatar
Pitcrw6
You sure about the steel tank for a 99 F350? I know the F450 and up had them.
Old Aug 25, 2013 | 10:23 PM
SpringerPop's Avatar
SpringerPop
I believe the cab-n-chassis F-350s had steel tanks. Is that what it is?
Pop
Old Aug 26, 2013 | 12:05 PM
NewFordUser
Will Check Nut On The IPR . And Will Try Too Get Analyzed As Soon As Possible .
