20O3 question for you. Mostly Engine....Update....
Old Aug 25, 2013 | 06:27 PM
Yahiko's Avatar
Yahiko
Here is the scoop My friend has an 03 F250 4X4 extended cab
EGR delete No cat resent turbo
1st
What would cause a clunk in the left front when going over bump at speed?
I need some ideas on what I should be looking for.
2nd
I did a quick scan and clear of codes to remove the EGR codes.I did a bad thing
and did not write then down. I did see a cyl 1 contribution code and a pair of
glow plug codes. Cleared and ran the KOEO got a cyl 1 low.
He had to get off to a dinner and will come back later. What should I be looking for?
I did a quick battery voltage test and got 12.7 V. I did not have the FICM stuff programed
into my SGII. I will do that tonight before he comes back.
So being an 03 would I be looking at a 7 screw or a 4 screw FICM?
Any thing you can point out for the next visit.
BTW he was over to help me deal with a Rabbit problem. That will be dinner in a short bit.
Sean
P.S. When he comes back over I will save the codes I get after he drives it a little.
Old Aug 25, 2013 | 06:48 PM
69cj's Avatar
69cj
Hey Sean, on item #1 I would think either ball joints or stabilizer bar links. Don't think wheel bearings would be the cause unless totally trashed and there would be other signs then.
Item #2 if I recall the early 04 and 03's had the 7 pin and the 05's and up were 4 pins.
Old Aug 25, 2013 | 07:14 PM
Yahiko's Avatar
Yahiko
Thanks
If it is a FICM can I use my backup one for testing it's a 4 pin?
One of the things I am dealing with is I am not driving it.
He dose need to clean the batteries.
I left him a message to see if he has a us spring in.
Just have to wait and see.
Sean
Old Aug 26, 2013 | 03:15 PM
Yahiko's Avatar
Yahiko
BUMP
Sean
Old Aug 26, 2013 | 03:58 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Hey Sean, is the truck running badly? As you know already the contrabution/balance code has a good chance of being injector. (Duhh )
Here's a bit of info that may be helpful, with all the toys..I mean tools you have I'm sure you have an inductive ammeter in you box .
Install an inductive ammeter on one bank at one of the two harnesses at the Glow Plug Controller Module (GPCM). You can get up to 200 A at first, but then should stabilize around 35-45 A. Check the other bank with the inductive ammeter. Both sides should read the same. If not, check the amps to each individual glow plug to determine which one (or ones) is bad. Each glow plug should draw 10-12 Amps. Each GP should Read between 0.5 and 2.0 ohms.
Old Aug 26, 2013 | 04:33 PM
Yahiko's Avatar
Yahiko
He said that he gets a black puff at start up. As you well know we tried to get it
to give us a puff and it did not this time just because it KNEW I was watching it.
Other then that it is running well.
I am going to have it here for a few hours because he has a parking brake problem
and I need to pull the rear wheels and rotors so it will have time to cool so I can
check it. What happened is one day he put the brake on like always and there was a pop
and the peddle went down easy and no parking brake. I put the brake on and was
able to really pull down on the cable before I could see the backing plate levers stop
moving. What I am thinking is the shoes are shot. I will check when I get the rotors off.
The one problem I will have to deal with is I can't get a complete self diagnosis
to run because of the way the EGR delete was done. The program halts at that
error. I need to see if he even has the valve. If not I tell him to ask the shop that
did the work to loan/give him a valve for this test.
Speaking of did the 2003 need the valve to make the fan work right?
Thanks for the input Rusty
Sean
Old Aug 26, 2013 | 05:19 PM
Rusty Axlerod
I think the 2003's didn't set a CEL if the EGR was unplugged IF the flash hasn't been updated but the missing info from the EGR valve still messes with the fan operation.
Old Aug 26, 2013 | 07:18 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
One thing I have noticed is smoke from the tailpipe (especially a puff) looks a lot worse than it really is if you're watching from outside the truck.
Josh
Old Aug 26, 2013 | 07:47 PM
BLADE35's Avatar
BLADE35
I just fixed a clunk when I hit bumps in mine
it was the leaf spring bushing
The REAR Mounts On the FRont Leafs
I could see the Rubber Bushing pushing out of there
Here the bad one below Pic I Pulled it right out By Hand
the rest I had to Press out
Check it out its Easy
Old Aug 26, 2013 | 08:23 PM
npccpartsman's Avatar
npccpartsman
A 2003 with a California flash will set a CEL for the EGR.
Old Aug 27, 2013 | 01:30 AM
Yahiko's Avatar
Yahiko
Thanks everyone.
This gives me some thing to look at on his truck.
I will update you as I get more info.
Sean
Old Aug 27, 2013 | 05:27 AM
npccpartsman
Originally Posted by Yahiko
Thanks everyone.
Sean
FICM's don't matter. If you have a working one then slap it in his truck.
Old Aug 27, 2013 | 05:47 AM
Yahiko's Avatar
Yahiko
Thanks good to know.
Sean
Old Aug 27, 2013 | 09:19 AM
69cj's Avatar
69cj
Don't forget to check the radius arm bushings. I've had them go out before on a van and they also clunk.
Old Aug 27, 2013 | 10:23 PM
Yahiko's Avatar
Yahiko
Well we found the clunk.
Tie rod end is shot.
And NoEGR valve plugged in. So I'll have him find one.
And on top of this I come home with the ABS light on and
it was the stupid right side sensor AGAIN
Last time I cleaned the plug and it went away. So I am
thinking that maybe a bad wire into the plug. Time to dig
Sean
Beau Patin
Aug 28, 2018 09:05 AM
BOLINJORDAN
Aug 14, 2009 08:17 PM
Budlight592
May 15, 2009 05:49 PM
redrider77x
Dec 11, 2006 01:55 PM
4.9inline6
Jun 2, 2006 06:16 PM
