6.0 killing while driving
Old Aug 27, 2018 | 06:09 PM
Beau Patin's Avatar
Beau Patin
Hey guys I’m new here but need serious help! I bought an 05 f250 king ranch a couple months ago and now it will sometimes kill as if I ran out of fuel while driving. I cycle the key a few times and it will crank for a minute then start up. It has a new turbo and an egr delete on it. I just changed the fuel filters a few days ago. From what I read on here about the ficm it seems like it wouldn’t start or run at all if that was bad so I’m kinda perplexed. Oh I guess I should mention the last 2 times it did that to me was 4 days apart. Any ideas please? I really need to get this fixed before it leaves me on the side of the road and I don’t have a whole bunch of money to throw at a mechanic. Thanks guys.
Old Aug 27, 2018 | 07:03 PM
xcrsp440's Avatar
xcrsp440
Gotta get a tool to read codes and sensor outputs. Download the Forscan app and get an obd2 adapter that will be read by your iPad or phone.
Otherwise just guessing.
Old Aug 27, 2018 | 08:31 PM
Beau Patin's Avatar
Beau Patin
I got a programmer and the only codes were about cylinder 7 and 8 contribution and egr circuit which I turned the egr off. Would the fact there is no egr but it wasn’t deleted maybe cause that?
Old Aug 27, 2018 | 10:15 PM
navistarnut's Avatar
navistarnut
The fact you have two contribution codes is pretty telling right there.
Does it act like it's missing when you are driving? It's also possible they are old codes.
Clear the codes to see if they come back
You need to be able to read data live in order to start pinpointing problems
Old Aug 27, 2018 | 10:37 PM
rocco7869's Avatar
rocco7869
Sounds like you may be getting air in the fuel lines. You said you just recently changed fuel filters. Check and make sure they are tightened good and also check the o-rings in the caps and make sure they are both good (make sure they didn't get damaged during replacement). Also after you change the filters, make sure you cycle the key on for 30 seconds and then off atleast 3 times. This is to purge the air.
Old Aug 28, 2018 | 04:52 AM
Beau Patin's Avatar
Beau Patin
I cleared the codes and drove to work this morning. Once I got to work I checked again and there was a cylinder 7 contribution, cylinder 7 misfire detected, and cylinder 7 glow plug circuit open codes. I can connect this programmer to my laptop and view live data but honestly idk what I’m looking at
Old Aug 28, 2018 | 04:55 AM
Beau Patin's Avatar
Beau Patin
It was doing this before I changed the fuel filters but I did double check the o-rings just to make sure and when I changed them I did cycle the key like you mentioned.
Old Aug 28, 2018 | 06:59 AM
bismic's Avatar
bismic
Did the engine dying issue begin after or before the fuel filter change?
Did you drain the water when you changed fuel filters?
Was the fuel or the filter very dirty or contain much water?
Have you checked the primary fuel filter cap o-ring to make sure it wasn't damaged? Same for the WIF (water in the fuel) drain plug ...... make sure the threads on the plug are good and the o-ring is good.
Typically a programmer is not the same as a scan tool when it comes to reading codes or pulling PCM information. Yours might be, but probably not. Tell us what you have ..........
As xcrsp440 suggested, ForScan will do the best job at scanning for codes. Just because you can get a few codes with a programmer or a scan tool doesn't mean that all the codes are being retrieved. Just like code readers, not all scan tools are equal. The Torque App and ForScan both do well at reading the PCM parameters from the sensor outputs (PIDs). They are phone apps and only require an ELM 327 adapter (bluetooth for the Torque Pro App and WiFi for the ForScan App). The ScangaugeII can give you PID information as well. It is clunky and a little expensive, but good for PIDs (not a good code reader though).
PIDS you need to retrieve and post first:
- FICM voltages (MPower, LPower, and VPower). The FICM is the computer that controls the fuel injection process. The FICM takes 12 volt Vehicle power and supplies it to the Logic board for Logic power and also steps up the voltage to 48 volts in the power board to send to the injectors (MPower).
- ICP pressure in PSI. ICP is "Injection Control Pressure". Your injectors are actuated with high pressure oil (you do not have a high pressure fuel pump).
- IPR % duty cycle. The IPR is the regulator (valve) that actuates to control the high pressure oil pressure at the desired point as determined by the PCM.
We need to see these values when cranking on a cold engine, when cranking on a hot engine, and at idle (hot and cold).
You also really should get a fuel pressure gauge. We did not even get a sensor for that from the factory, so you would need to add a sensor AND a gauge. Lots of threads on that. You need to read up on that - very important.
If you have low fuel pressure or air in your fuel, you will damage injectors and end up spending a LOT of money.
Check your fuel for bubbles (two person job). Remove the cap on the upper fuel filter. Remove all the fuel, Then turn the key on to fill the bowl. Look for bubbles as the bowl fills.
Old Aug 28, 2018 | 09:05 AM
Beau Patin's Avatar
Beau Patin
I have a sct model sf3 programmer. I don’t know much at all about programmers. That one just came with the truck. As far as the o-rings, I put brand new I-rings on when I changed the filters and the truck was killing like this before I changed the filters. Ill try to get my hands on a forscan this afternoon. Thanks guys
Hayes9000
Apr 16, 2022 07:17 AM
meetre
Feb 23, 2015 10:29 PM
wulfman
Aug 28, 2010 06:44 PM
eprn1n2
Jan 27, 2009 04:42 PM
deercreek1
Nov 12, 2007 11:58 AM
