does anybody have a schematic for the later crew cabs that have all 4 windows with power? I finally have the regulators for my rear windows, and I have a crew cab Master door panel and switch, but I want to make this as little jerry rigged as possible. I'd like to have the lockout switch and everything wired up properly.
if anybody can message me with a schematic or even email it to me, I'd be mighty obliged.
The best way to go about adding power windows would be to get a power window truck harness and wire it into the fuse panel
I'm totally all for it Brad. Unfortunately those CC's in the junkyard are torn apart the second they arrive. And if I do it that way, I can have it wired for keyless entry and a rear seat dome light too. Although the dome light is pretty easy just to wire in
If this works, here's the wiring diagram I found on-line.
edit: Boy that came out small. I haven't tried to post .pdfs before. Don't know if you'll be able to get anything from that, but I just found it on-line (sorry, I don't recall where)
