2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Switched 12 volt connection??
Old 04-12-2014, 02:25 PM
mwells's Avatar
mwells
mwells is offline
I have an external GPS with back-up camera. The 12 volt accessory plugs on the dash are always on. I want to connect to a switched 12 volt source, so I can leave my GPS plugged in all the time. Mfg. warns to unplug the unit before starting the vehicle, so always on connection is a pain (already trashed the adapter). The interior fuse box has several "spare" spots, but need to know a wire color I could tap into to provide switched power to the GPS. Please help.
Thanks.
Old 04-18-2014, 10:08 PM
Ford'05HG's Avatar
Ford'05HG
Ford'05HG is offline
Honestly if I were you I'd just tap the positive of your outlet into the ignition accessory wire. That way it'll charger whenever the key is on but automatically cuts power to the outlet when starting.
Old 04-19-2014, 08:37 AM
mwells's Avatar
mwells
mwells is offline
thx to Ford'05 HG
Thank you for the suggestion. Not sure why I did not think of that myself - duh!
I have not looked at the back of the ignition switch yet, but any idea what color that wire may be?
Old 04-22-2014, 08:56 AM
Ford'05HG's Avatar
Ford'05HG
Solid black with a green stripe. Should be a 12 ga wire.
Old 04-22-2014, 09:01 AM
Ford'05HG's Avatar
Ford'05HG
Actually I'm wrong. According to my sources your wires are (solid/stripe) brown/yellow and purple/green. Anyways, the wire should read positive when the key is on or acc neutral when starting or off.
Old 04-22-2014, 09:11 AM
mwells's Avatar
mwells
mwells is offline
thx to Ford'05 HG again
A thousand thanks!
Old 05-16-2014, 07:18 PM
TMKIOWA21's Avatar
TMKIOWA21
TMKIOWA21 is offline
Smile 12V ACC or 12V Batt
Im looking to do the same thing with tapping into ACC wire but I want use it to power my 9 Switches . Can i use that acc wire or should I run a 12v supply to the switches? there is no amp draw only uses power to tell the relay to turn on? any thoughts will help
Thanks
Old 05-20-2014, 10:28 PM
travelinl22's Avatar
travelinl22
travelinl22 is offline
I used the acc wire in the drivers kick panel
pacnorwest
1999 to 2016 Super Duty
21
07-22-2020 07:47 AM
lexustbs
6.7L Power Stroke Diesel
12-29-2010 11:21 PM
frogracer
2009 - 2014 F150
07-03-2009 05:08 PM
LaxPlaya21
03-30-2007 08:36 PM
hartmark
01-03-2002 09:05 AM
Quick Reply: Switched 12 volt connection??
