Sponsored by: Real Truck
Finding "switched power" source?
Old Jun 20, 2015 | 07:17 PM
pacnorwest's Avatar
pacnorwest
What's the best/easiest place to tap into a 12 volt power source that is turned off/on by the ignition key?
I have a supplemental braking system add-on that requires a "switched power" source.
Not off the battery (no switch there) and not off the fuse block (no switch there either).
My guess is that I need to find a power wire to the heater fan, power windows or other device that requires the key be in the on/acc position.
Question is; where to tap into that power source?
Any suggestions?
Old Jun 20, 2015 | 07:29 PM
Desert Don's Avatar
Desert Don
Any suggestions?
Do you have the upfitter switches? That would be my first choice.
Old Jun 20, 2015 | 07:36 PM
pacnorwest's Avatar
pacnorwest
The upfitter switches are not appropriate. . .I need the system to be "ON" when the key is ON.
There are a bunch of "blunt cut" wires under the dash. I'm thinking something like the PTO wire - may I can tap into that. . .and hoping that someone has experience in that area.
Old Jun 20, 2015 | 09:13 PM
Just Strokin's Avatar
Just Strokin
Fuse 10, 10a, feeds a Customer access wire in the right hand kick panel. The wire is White with Blue stripe and it is taped to harness near connector C210 which is a 59 pin connector.
The above info per 2015 Ford Service DVD
Old Jun 21, 2015 | 07:57 AM
Long Haul's Avatar
Long Haul
see if this helps..
Keep in mind I have a 2011 w/6.2L
I don't remember the exact location but this gives you an idea, multi meter or test light can handle the rest..
I didn't have much luck with the passenger side fuse box down by the kick panel....Not enough room for a fuse tap so went under the hood and thru the firewall.
Old Jun 21, 2015 | 08:54 AM
pacnorwest's Avatar
pacnorwest
The fuse block is HOT all the time, isn't it?
Or does the on/off switch activate the fuse block?
I did some fuse block testing with a meter and the key OFF - the fuse block was HOT all the time. . .even the empty blank fuse holder spots were hot.
The question is to have "switched" power - power that comes on when the ignition switch is turned on.
Old Jun 21, 2015 | 09:00 AM
pacnorwest's Avatar
pacnorwest
I had the right side kick panel off yesterday.
By "customer access" wires, I assume that it means "blunt cut" wires.
There are NO blunt cut wires under the right side kick panel.
I pulled the side panel, the glove box and the under dash cover - and inspected for blunt cut wires: none found.
I also pulled up the trim covers along the edge floor passenger side: no blunt cut wires.
I will re-inspect the taped harnesses under the right side kick panel today.
Old Jun 21, 2015 | 09:33 AM
Long Haul's Avatar
Long Haul
yes and no...
Most are hot, the one I used is switched I triple checked it with a test light..
Old Jun 21, 2015 | 09:42 AM
pacnorwest's Avatar
pacnorwest
Okay Mike! Good information there.
Your 2011 fuse block fuse locations are different than mine.
(I don't have it memorized but I see some minor variations in fuse locations.)
I'll do some testing and try to find a switched fuse location today also.
Old Jun 21, 2015 | 09:56 AM
Long Haul's Avatar
Long Haul
On my 2011 its #51 as seen on the diagram in the owners manual..
ignition key on..
ignition key off..
YMMV....
Old Jun 21, 2015 | 09:57 AM
Long Haul's Avatar
Long Haul
I guess you posted as I was typing !!
good luck..
Old Jun 21, 2015 | 01:52 PM
pacnorwest's Avatar
pacnorwest
Very frustrating.
There is supposed to be a white/blue wire in the blunt cut bundle under drivers side dash.
It's even printed on the wire bundle tag as WH-BU RUN/ACC
But there is no white with blue stripe wire!
This would be the ideal place to tap into a "switch on" power source.
I've checked for power on several of the larger 18 gauge wires for power and no joy.
Old Jun 21, 2015 | 01:59 PM
Long Haul's Avatar
Long Haul
bummer..
The only other thing I could think of would be tie into a constant hot, run it to a toggle switch, and make it switched by turning the toggle on/off.....kinda ghetto I know, but...
Old Jun 21, 2015 | 05:33 PM
pacnorwest's Avatar
pacnorwest
My guess is that maybe the driver's side blunt cut wires do not have fuses installed.
Ford could save a lot of money that way. I would have used one of the blunt cut wires if I knew which fuse slot worked for it.
Instead, I managed to install a fuse tap on the passenger side fuse block. (#33 Restraint control modual.)
There is just enough room next to the center relay. I had to cut an wire escape slot in the cover's side.
The cover will snap shut.
The fuse slot is hot only in the run position.
So. . .this will work but I wish that the blunt cut wires were of more use.
There should be a fuse for the PTO. . .but looking at the fuse block diagram, there's no PTO fuse. . .that seems kind of odd. Same for the RUN/ACC blunt cut wire. . . .there's no indication that it's fused. I'd like to do it proper but will have to forgo that for now.
Old Jun 21, 2015 | 05:42 PM
Long Haul's Avatar
Long Haul
thats good news..
