Sponsored by: Real Truck
What Am I Doing Wrong?
Old Mar 30, 2007 | 06:51 PM
LaxPlaya21's Avatar
LaxPlaya21
Ok, I feel horrible writing this and wasting peoples time but I can't figure this out.
I did the HID retrofit on my truck. The high beam solenoid on the projector that controls the shield has a positve and a negative wire. I decided to wire them temporarily to a Upfitter Switch. I found the Upfitter Switch #1, i think it is ornage with a green trial. Now I ran a red power wire from that orange upfitter switch through the firewall then I split it to the power wire on the two solenoids. The black wires on the solenoids I ground to the truck. Am I hooking up the Upfitter Switch correctly?? I have no power. Is the Orange w/ green a power wire?? Sorry for the stupid question I have been searching but just can't seem to get an answer.
Old Mar 30, 2007 | 07:11 PM
rwilimo's Avatar
rwilimo
Here's the info for the Upfitter's:
Aux-1 Circuit No 1936 wire color: Orange/Lt. Green [30amp]
Aux-2 Circuit No 1933 wire color: Orange [30amp]
Aux-3 Circuit No 1934 wire color: Orange/Yellow [10amp]
Aux-4 Circuit No 1935 wire color: Orange/Lt. Blue [10amp]
Did you test the Upfitter wire for power? If you have no power I would start by testing the fuse. Out of curiosity, Why wouldn't you use the high beam wire to trigger the solenoid's?
Old Mar 30, 2007 | 07:20 PM
LaxPlaya21's Avatar
LaxPlaya21
The problem I am having is that I need the high and the low to stay on... because unlike the dual filament 9008 bulbs where they are not on at the same time... the HID bulb is always on low, and the high is just movemnent by the solenoid of the shield in the projector.
According to they way I described the hookup... I should have power though correct? I don't have any real ways to test for power on this except for hooking up the solenoid. Thanks
Old Mar 30, 2007 | 07:27 PM
rwilimo's Avatar
rwilimo
First you need to get yourself at least a test light. Without this you will have great troubles figuring anything out. As far as high beams, it would be a little more work but you could build a simple circuit with a relay to make it work off the high beam switch.
Good luck.
Old Mar 30, 2007 | 08:36 PM
LaxPlaya21's Avatar
LaxPlaya21
Good luck.
Ok, I got them wired off the #1 upfitter. The 30amp fuse was loose in the glove box! Yes I will actually be using a diode to connect the low and high beams together on an aftermarket wiring harness I have. Thank for your help.
twack
Sep 19, 2022 08:33 PM
Ray Hamel13
Aug 21, 2014 06:13 AM
ROBBINthaHOOD
Apr 1, 2014 08:52 PM
brucedog
Jan 27, 2009 09:41 PM
tim241
Electrical Systems/Wiring
Oct 8, 2006 08:06 PM
