1978 - 1996 Big Bronco
'79 Bronco...help please!
Old Sep 8, 2013 | 01:31 PM
  #31
scott79's Avatar
scott79
Yes, if that's where it was when he pulled off the lockout. Like Raleigh1 said, it should be between the outter gear and retainer plate, just like the diagram shows!!
Originally Posted by GruesomeJeans
So #13, the spring is not in the right place huh? That's not good...
Old Sep 10, 2013 | 12:24 PM
  #32
blackjack33's Avatar
blackjack33
Yeah, that spring....
It's supposed to be underneath the "ring gear"...that's what engages/disengages the hub lock as you turn the selector ****.
There's two springs contained on the inner assembly of the Warn standard hubs. One is a captured spring that is under a lip on the free/lock ****...the other bigger one is under the ring gear.
Looks like my mechanic buddy took the hubs apart for some reason and forgot how to reassemble them correctly.
It took me awhile to figure it out but I got it straightened out...operates as is should.
Thanks again for the help guys.
Tri865
Jan 22, 2014 04:08 PM
HareBall
Dec 31, 2008 07:18 AM
u1cracka
Jun 30, 2008 05:52 PM
Zoltrix
1997 - 2003 F150
Feb 14, 2007 07:33 AM
Jeff Pugh
Sep 1, 2003 02:10 AM
