Low fuel pressure ???
Old Aug 19, 2013 | 04:46 PM
jetact's Avatar
jetact
I was driving and noticed my fuel pressure on my Edge CTS was 31 PSI. Truck was running fine. No miss or sputter or anything. I have the blue spring mod. Got to my location and changed my fuel filters. Same reading. I took the hose off and hooked it to an old gauge that I had and roughly the same reading. The truck started fine after the filter change and runs fine also. No clue what is wrong. Any ideas??
Old Aug 19, 2013 | 04:53 PM
mustang_309's Avatar
mustang_309
the pump is probably dying on you.
Old Aug 19, 2013 | 05:00 PM
jetact's Avatar
jetact
Thanks Mustang, I have 86,000 miles on it and owned it since new. Guess I will order a new one.
Old Aug 19, 2013 | 05:03 PM
mustang_309
Anytime bud, i just had to replace mine at 88000.
Old Aug 22, 2013 | 10:48 PM
jetact's Avatar
jetact
Update: Well I bought a new fuel pump and installed it. That didn't change anything the fuel pressure was still 30 PSI. So my guess was broken spring or something in fuel regulator. So pulled it apart to find that the oring around the brass insert was broken. So my guess is it was allowing fuel to bypass and giving me a low pressure reading. Going to get a new blue spring kit in the morning and reinstall it and see if my pressure comes back. I am tired of smelling like diesel.
Old Aug 22, 2013 | 11:34 PM
99ExpyProblems's Avatar
99ExpyProblems
Nothing worse than just throwing parts at it. Glad you found the culprit. I hope it works out for you!
Old Aug 23, 2013 | 06:50 AM
mustang_309
That sucks Bro, mine acted just like you described and it was the fuel pump, but if that does the trick now you have a backup.
Old Aug 23, 2013 | 10:57 AM
skidooman1990's Avatar
skidooman1990
Sir, the scent of diesel, in my opinion, never gets old.
2003 EXCURSION
Jul 31, 2016 06:56 PM
97powersmoke
Feb 16, 2014 06:50 PM
JOHN2001
45
Sep 25, 2013 03:43 AM
srauner
15
Jul 30, 2010 08:22 AM
64F260
Apr 30, 2010 05:23 PM
