Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Where can I get a new compressor tank?
Old Jun 14, 2003 | 07:57 PM
SDawgz's Avatar
SDawgz
I have a quiet little, 20 gal, compressor that I was given that has a problem, there is a hole rusted through the tank. I need a new tank but Grainger wants $175 for just the tank. Does anyone have any suggestions where I can get a new tank for $50 or less?
Old Jun 14, 2003 | 08:23 PM
TexasBronco's Avatar
TexasBronco
Try ebay
Air Compressor Tank
Old Jun 14, 2003 | 10:08 PM
Torque1st's Avatar
Torque1st
Posting Legend
Local scrap yards will often have used tanks. Check in your yellow pages and find a pressure testing service to have the tank tested tho.
Shipping on a tank is high.
Old Jun 16, 2003 | 11:10 PM
angus's Avatar
angus
Try placing a classified ad. There must be tons of burn-out oilless (direct-drive) compressors out there with usable tanks, if they're as bad as people say.
Old Jun 16, 2003 | 11:20 PM
Torque1st's Avatar
Torque1st
Posting Legend
Drive around on bulk trash day. In our city we have a large item trash day twice a year (spring/fall). Maybe garage sales also...
Old Jun 18, 2003 | 09:29 AM
cwb's Avatar
cwb
Don't know how you feel about welding on a patch. If it has rusted through from the inside you had better toss it. Mkae sure the weld is GOOD.
Old Jun 18, 2003 | 10:47 AM
cigarxtc's Avatar
cigarxtc
Hey Sdawgz, where you located in OK? I had an oil compressor a couple years ago with a rusted out tank. I had a local welder put some patches on the bottom where the holes were all the way through. It worked, but that was more of a temporary solution. I eventually bought a new compressor and gave my old one away to a buddy. Just for grins I opened the local yellow pages to see if there was a tank supply place locally and there just happened to be several businesses listed in Tulsa that could have supplied me with a new tank. Oh well, live an learn. I'd try the local yellow pages.
Old Jun 18, 2003 | 08:18 PM
TheWiz427's Avatar
TheWiz427
Check the local compressor repair shop they should have a used one or new as well.
Old Jun 18, 2003 | 11:55 PM
MisterCMK's Avatar
MisterCMK
My grandpa used to use an old LP tank. He would make sure that is was empty, and then he would put new fittings on. Even after being aired out, it still reeked really bad. My dad used to have an old 20 gallon before he got the new one. The 20 gallon had holes in the tank. He rigged it up so that the new tank was one of those small tanks that you can take with you when you go camping or whatnot. It worked ok for a blow-gun and occasional impact-wrench. He bought a new 60 gallon unit, and it can run any air-tool all day. Also, I don't have to wait for the compressor to catch up when using the pneumatic can crusher.
-CHRIS
Old Jun 22, 2003 | 07:46 AM
SDawgz's Avatar
SDawgz
These are some great suggestions, it looks like I have more places to look than I thought. cigarxtc - I live in Broken Arrow.
Shawn
Old Jun 22, 2003 | 11:10 PM
BroncoRoadKill's Avatar
BroncoRoadKill
Hey all, Me and my family have olways used properly cleaned out propane tanks of varius sizes. They work well for 130psi.
Old Jun 28, 2003 | 01:12 AM
96ExtracabPSD's Avatar
96ExtracabPSD
I had the same thing happen with my little $20 yard sale compressor. I took two air tanks off of a truck that we were parting out and made a small twin tank compressor. Plumbed the airline from the compressor into one end of one tank, connected the other end of that tank to the second tank, and plumbed the outlet fitting into the other end of the second tank. That was hard to type
Anyway it works great now, and will hold air for over a week without kicking on.
Old Jun 28, 2003 | 12:10 PM
MisterCMK's Avatar
MisterCMK
They don't stink too badly? That's the problem we had when we had the old compressor.
Old Jun 28, 2003 | 02:59 PM
Torque1st's Avatar
Torque1st
Posting Legend
Wash them out with soap and water a couple of times then fill completely to rinse several times.
Trojan8975
Aug 6, 2011 09:08 PM
breedo99
13
Mar 25, 2010 09:07 PM
Neal 97 250
21
Sep 26, 2007 08:26 PM
cobraii
Sep 23, 2003 08:49 PM
rockfiv0
Dec 12, 2002 04:42 PM
