gearing
Old Aug 12, 2013 | 05:27 PM
blazer350's Avatar
blazer350
gearing
can someone tell me how I can tell what gears I have in my truck. I have a 69 f-100 with a 240 and a 4 on the floor. will the vin have that info. thanks
Old Aug 12, 2013 | 06:11 PM
Area351's Avatar
Area351
Crawl underneath, read the tag on the differential housing.
Old Aug 12, 2013 | 06:18 PM
JEFFFAFA's Avatar
JEFFFAFA
No it won't. There is other coding on the door. But that tag and the rear end would both have to be original. S000000, 2x AREA351.
Old Aug 13, 2013 | 03:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
AXLE code stamped on 2nd line-far right of the Warranty Plate, located on the left door face below the latch.
But, who knows today if the R&P is the original?
9 inch: AXLE ID tag located under one of the bolts (usually at 5 'clock) that retains carrier to housing.
By now, many of these tags have gone bye bye.
Old Aug 13, 2013 | 04:39 PM
Area351's Avatar
Area351
If all else fails:
With truck in neutral and front wheels chocked, Jack up one side of the rear axle and turn tire one complete revolution while counting the revolutions of the yoke at the drive shaft. Put a chalk mark on both the tire and yoke as a reference.
If for example you turn the wheel one rev and the yoke turns 3 1/2 times, you have 3.50 gears. If it turns 2 1/2 times you have 2.47 gears and so on.
Someone else will come in with all available OEM axle ratios but it could be anywhere from 2.xx to 4.xx
Old Aug 13, 2013 | 10:51 PM
blazer350's Avatar
blazer350
THANKS FUR THE HELP ILL CHECK IN THE AM
slowrollerzcustoms
Jul 18, 2014 10:45 PM
ufvj217
Nov 22, 2012 02:30 PM
stallion3599
Jul 24, 2012 06:58 PM
FordManMT
Feb 4, 2011 04:21 AM
duke1992lx
Aug 2, 2007 08:54 PM
