Gears
Old Jul 16, 2014 | 01:38 PM
slowrollerzcustoms's Avatar
slowrollerzcustoms
Gears
I need to know what gears i have in my 9" and d44 from a f150 sc with a c6 trans had 351m
Old Jul 16, 2014 | 01:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
AXLE code stamped on the 2nd line...far right of the Warranty Plate, located on the left door face below the latch. Code may/may not have front driving axle info.
Dana ID tag located under one of the bolts that retains the inspection cover to the housing.
Ford 9" rear axle ID tag located at approx. 5 o'clock under one of the bolts that retains the carrier (pumpkin) to the housing.
One or both of these ID tags may be missing by now.
Old Jul 16, 2014 | 02:46 PM
slowrollerzcustoms
155 sm x143 kbm g 16a
06400 1978 54
slowrollerzcustoms
id tags gone
Old Jul 16, 2014 | 04:07 PM
slowrollerzcustoms
i decoded my vin i have 3.50 gears
Old Jul 16, 2014 | 05:13 PM
HIO Silver's Avatar
HIO Silver
Consider estimating the rear gear ratio using engine RPM, tire height, and a 1:1 final drive ratio.
As you may recall back in your algebra days, solve for x.
Engine RPM / Engine Speed Calculator
Old Jul 16, 2014 | 05:17 PM
slowrollerzcustoms
no a guy is interested in buying the axles so i had to get the gear ratios
Old Jul 17, 2014 | 12:30 AM
moonley's Avatar
moonley
So I assume the truck is not running, in which case go to this link http://www.crankshaftcoalition.com/w...ar_ratio_check scroll down and read the "rotating the tires method". Otherwise you will need to pull the covers and count the teeth.
Old Jul 17, 2014 | 08:45 PM
NumberDummy
Originally Posted by slowrollerzcustoms
WB: 155 / COLOR: SM / TYPE GVW: X143 / BODY: KBM / TRANS: G / AXLE: 16A / MAX GVW LBS: 06400 / YEAR: 1978 / DSO: 54
155" Wheelbase.
SM: S = Bright Dark Blue Metallic / M = White.
X143 = F150 4WD Super Cab Pickup.
KBM: KB = Blue Vinyl & Blue Cloth (Lariat) / M = Super Cab.
G = C6.
16A: 16 = Ford 9" Rear Axle / 3.50-1 / No Limited Slip / 3,750 lbs. Rear Axle Capacity / A = Adjustable Steering Column with P/S.
6,400 lbs. Gross Vehicle Weight Rating.
1978.
54 = Omaha NE Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Jul 18, 2014 | 12:45 AM
moonley's Avatar
moonley
Ah, I missed that part. But on a truck this old I would never trust the gearing based on the tags, too many years have gone by with opportunities for people to change things. I still recommend double-checking by using the rotating tires method or counting the teeth.
Old Jul 18, 2014 | 02:40 AM
NumberDummy
i decoded my vin I have 350 gears.
No VIN contains the axle code, it's stamped on the 2nd line-far right of the Warranty Plate.
See post 9.
Old Jul 18, 2014 | 07:05 PM
slowrollerzcustoms
its all factory the truck was parked and sat in a field at 60,000 miles original
Old Jul 18, 2014 | 10:45 PM
NumberDummy
its all factory the truck was parked and sat in a field at 60,000 miles original.
Do NOT believe the miles shown on the odometer, as it reads to 99999.9 then returns to ZERO!
Crooked used car dealers and owners alike rolled back many odometers before the gov't stepped in (mid 1980's) and made it a felony to do so.
Truck Guy99
Feb 3, 2014 04:34 PM
blazer350
Aug 13, 2013 10:51 PM
Sayer Lane
Jul 4, 2009 03:45 PM
78'Ranger
Jul 23, 2007 07:10 PM
jmono
Dec 28, 2005 01:18 PM
