build sheet
Old Aug 9, 2013 | 01:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Marti can provide a new Warranty Plate with correct codes stamped on it...as long as OP comes up with the correct VIN (this is illegal in some states, but most peeps are unaware).
But, the Warranty Plate is not that important, because the VIN that is stamped on it, is not used by DMV and/or Law Enforcement for title or registration purposes, as it's too EZ to change.
For example: Swapping damaged left doors with used doors. What percentage of the people installed the original Warranty Plates on the replaced doors? Probably less than .001%
For title/registration purposes: DMV/Law Enforcement go by hidden frame VIN and it could be anywhere, as location varied based on assembly plants.
1981: When I pulled the engine from my '65 F100 (I bought it new, assembled @ San Jose 1/1965), VIN was stamped on the engine cross member directly below the harmonic balancer.
Beginning circa 1988, in an effort to cut down on thefts, the NHTSA mandated that automakers stamp the VIN on all sorts of mechanical/body parts. VIN also printed on stick-on labels that resist being peeled off.
Old Aug 9, 2013 | 02:12 AM
The Masked Rider's Avatar
The Masked Rider
Maybe not the warranty tag, I agree, but the frame is. That subed in frame must come papered or it needs a Ref. AND pass that its not stolen. I still hold that the title is worthless unless you have the frame to match.
Course its really none of my business. I only meant to offer a little info on what I've experienced. Think about this. If he checks into it and finds out it IS stolen- then what do ya do, give it back to the dealer knowing its stolen and just say nothing to local law enforcement. Or give it back before you know for sure. I sure as hell wouldn't want that on my conscience. I DO wish him good luck. And I think I'll just stay out of it. I've said too much already.
Old Aug 9, 2013 | 10:16 AM
Gembone's Avatar
Gembone
I have a problem with the fact that the vin on the title doesn't match either other vin on the vehicle. It should match at least one of them to even be considered belonging to the truck. Dealers have ways to get titles for vehicles, so why does this one not match?
Old Aug 9, 2013 | 11:35 PM
nvrgrwup's Avatar
nvrgrwup
Hey Masked Rider, I couldn't agree more which is why I'm going through this frame vin thing, yuk! So just now I've sent three report requests to Marti to compare what I have with what the vin's say I have.
When they come back (they say 10-14 days) I should have a clearer picture of what has happened. I really don't want to go to the authorities or back to the dealer unless I have at least most of the answers to the questions.
I'll post my findings when it all comes back, thanks everyone, Russ.
Old Aug 10, 2013 | 12:13 AM
NumberDummy
Run all 3 VIN's thru the TN DMV .. see what happens. Dunno about TN, but in CA this can be done by phone (800 number) or online.
If you post these 3 VIN's, I can decode them.
Old Aug 10, 2013 | 01:06 AM
Ford_Six's Avatar
Ford_Six
When I moved to Idaho, the sheriff had to verify the vin number so I could register my truck. They used the door tag for this. Given that you may need to remove the cab from the frame to verify the chassis vin, I can't see anyone doing this short of some sort of forensic situation.
I would write all three vins on a scrap of paper, and go in to the DMV saying you are looking at a few trucks, and would like to know if there would be any issues with registration.
Old Aug 10, 2013 | 03:59 AM
NumberDummy
Sheriff looked at the VIN on the registration, compared it to the "VIN" on the Warranty Plate, it matched.
Be thankful your truck has its original left door.
Here's a sample of a 1964/65 US truck Warranty Plate. Notice: NOT FOR TITLE OR REGISTRATION PURPOSES is printed below the "VIN" that FoMoCo referred to as the 'Warranty Number' on Warranty Plates.
I typed it in capital letters as that's how it was originally printed. I have a 27" monitor, but others may not, might be difficult to make out wording in pic.
Old Aug 10, 2013 | 11:25 PM
nvrgrwup's Avatar
nvrgrwup
O.k. folks here goes! Number Dummy, thanks as always for valuable info. I don't see a good reason why I should not post the VINs so...This is probably gonna get long.
Title- F10ANM81468
Data Plate- F10GLP84815
Frame- F10WLM47678
The title is what the dealer provided from the previous registration surrendered by the previous owner. They say they were advised by the DMV that if it was registered that way once, just re-register it! What a way to do business. The data plate has been either removed or replaced. Slightly bent plate, not fully seated rivets, but both are factory style.
Frame # is from a tracing I took and am FAIRLY satisfied with all except the engine letter. Simply could not read it so I picked the W. It could be the 360 (Y) of course and I'll try that next time if Marti says it isn't valid.
The frame has an FE with a C-6 and I believe a 3:25 diff.
Old Aug 10, 2013 | 11:39 PM
nvrgrwup's Avatar
nvrgrwup
continued. Almost all the numbers on components on the frame fall into the same general dates for a 72 model.
The body has all matching original panels. The factory paint lines (2 tone) are all visible beneath the primer and on the edges. Panel fit on front end is poor. Bolts on front end have been moved. Shift collar on column is grey primer as if a new part. No clutch pedal visible but.... If the body was swapped it was done a long time ago because of rust and condition of bolts and such. I won't put up with a stolen vehicle, but I also won't surrender it to the State to be crushed. Going after the dealer is an option but I really want the truck and with only $900. in it I'll use it for parts. I want to do the right thing and that's why I'm going through all this crap.
Anyway, don't any of you quit commenting because you've all helped and are appreciated. Going to get this thing solved yet, thanks, Russ.
Old Aug 11, 2013 | 07:09 AM
NumberDummy
OK folks here goes! I don't see a good reason why I should not post the VIN's.
Title- F10ANM81468
Frame- F10W LM47678
F10 = F100 2WD
A = 240 1V I-6.
N = Norfolk VA Assembly Plant.
M81468 = 1972.
F10 = F100 2WD
G = 302 2V
L = Michigan Truck Assembly Plant.
P84815 = 1972.
F10 = F100 2WD
W = No such VIN engine code / 240/302 decoded, other possibles: B = 300 1V I-6 / H = 390 2V / Y = 360 2V
M47678 = 1972.
Old Aug 11, 2013 | 02:23 PM
RichS2659's Avatar
RichS2659
Funny that these vin's are all 72's. I would check with Carfax to see if you get a hit on any of these numbers plus the vin on the Safety Certification sticker on the B pillar of the cab if it is legible (probably was scrubbed away with solvent) since the others come back as 72's.
Tennessee DMV even has a section where you can get a link for checking a car's history (Even though I couldn't see any links on my laptop. It might work for you.)
Old Aug 11, 2013 | 03:39 PM
elgemcdlf's Avatar
elgemcdlf
Get your money back. As stated dealers must adhere to certain laws & what you have is definitely a violation. Take the money & buy a different truck.
Old Aug 14, 2013 | 09:55 AM
  #28
nvrgrwup's Avatar
nvrgrwup
Here we go again folks. Feel like I'm making progress...two steps forward, one step back! Number Dummy, once again please? Engine code on the frame # was a late night brain fade, it is "H". Checked the stroke.
Here's what the data plate says, (will try to upload a pic tonight) under the engine code, G it's supposed to be a 302, but the net H.P. is listed at 134? Also the paint code is "T", but the truck body is clearly a two tone "combination" scheme in red and white, white roof, red upper body, white lower body?. The body code is 5 4, can't find that code anywhere. Going to go to the Tn. DMV web site and try there. Thanks, Russ.
Old Aug 14, 2013 | 10:11 AM
  #29
NumberDummy
Net HP @ the rear wheels. Gross HP @ the flywheel.
VIN engine code G = 302 2V / VIN engine code H = 390 2V
1972 Warranty Plate:
COLOR code T = Candyapple Red / Tutone red & white would be COLOR code TM ~ M = Wimbledon White.
BODY code 5 4: 5 = Medium & Dark Red Vinyl (Custom) / 4 = Styleside Pickup.
Riderman
Nov 2, 2009 06:46 PM
Taylor77
Dec 15, 2008 07:09 PM
Mirage
Nov 27, 2005 09:52 AM
BEAST428
Nov 11, 2003 05:23 AM
fordman1957
Aug 19, 2002 09:52 PM
