Connecticut Chapter Join Chapter, Leader:
Connecticuts August BS thread
Old Aug 6, 2013 | 05:57 PM
  #61
acf6's Avatar
acf6
simple brake fluid change/bleed just turned into a new caliper. so i now have a new caliper on. eating dinner then i can bleed my brakes, lol
Old Aug 6, 2013 | 06:15 PM
  #62
7.3 Rocket's Avatar
7.3 Rocket
Originally Posted by danorules
I'll try and let you know when it's posted, but check the town website every couple of days.it's usually there first. The position is in the parks dept, so highlight your mowing and plowing experience
Thank you, sir. My resume reads snow, grass, trees. All things in parks.
I also make sure "Class A CDL" is pretty prominent on any resume I send out.
Old Aug 6, 2013 | 07:35 PM
  #63
Nice Work Truck's Avatar
Nice Work Truck
Evening guys.
Miles you also might want to flush the power steering/brake booster.
It made a difference in the way my pedal felt.
Old Aug 7, 2013 | 04:17 AM
  #64
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Good morning guys.
Going to enjoy it while I can.
Hope everybody has a Happy Hump Day.
Old Aug 7, 2013 | 04:25 AM
  #65
acf6's Avatar
acf6
Good morning, this cool weather is so nice after July
I replaced my front right caliper last night but now my trick pulls to the left when I brake. I had to put my old rotor and pads on because my new stuff isn't here yet. Why would it be doing that?
Old Aug 7, 2013 | 04:27 AM
  #66
Nice Work Truck
Good morning Jim and everyone else.
Jim did you get your truck fixed ?
Old Aug 7, 2013 | 04:28 AM
  #67
Nice Work Truck
Miles do you have some air in that line ?
Old Aug 7, 2013 | 04:31 AM
  #68
acf6's Avatar
acf6
No I bled them a lot. Seems to be good after a few hard stops
Old Aug 7, 2013 | 04:34 AM
  #69
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
My truck, Andy???
Two Saturdays ago I fixed the coolant leak in my timing case.
I've been too busy during the day to get new radiator hoses.
I should just order them from Amazon or something.
Old Aug 7, 2013 | 04:35 AM
  #70
acf6's Avatar
acf6
Now it pulls to the right lol
Old Aug 7, 2013 | 04:43 AM
  #71
Nice Work Truck
Miles the new caliper and pads are griping better.
It should work in.
Jim good luck getting all fixed.
Old Aug 7, 2013 | 06:03 AM
  #72
gbroehl1's Avatar
gbroehl1
Good morning everyone. Have a great day.
Old Aug 7, 2013 | 07:41 AM
  #73
Submarine Docker's Avatar
Submarine Docker
Good Morning,
Got septic system straightened out - tank pumped, drain line snaked and then blasted. Now have to get everything covered back up. Think I'm going to use a pipe clamp patch on the cracked cast iron drain pipe. The pipe is not leaking now that the drain is not backing up. The crack extends to the coupling which passes through the stonewall foundation. Really hesitant to try cut it off and installing PVC. If the coupling cracks the I'm into a lot more expensive repair.
Hopefully will get to coolant flush, radiator replacement, and new water pump/belt/hoses today.
Have a good day,
Jim
Old Aug 7, 2013 | 07:16 PM
  #74
GuyPavelo's Avatar
GuyPavelo
Evening gents.
Just got back last night from the festival show up in toronto... another 2000 miles onto the truck overall. Working well!
Old Aug 7, 2013 | 08:10 PM
  #75
Nice Work Truck
Evening guys.
