ignition/electrical issues
Old Jul 27, 2013 | 02:28 PM
Chris Mullikin's Avatar
Chris Mullikin
I've got a 74 ford f100 302-c4 . Just got motor put in. It'll turn over but won't start. Does anyone have pictures of how solenoid should be wired up or have any other tips? Not getting spark.
Old Jul 27, 2013 | 04:07 PM
HIO Silver's Avatar
HIO Silver
Old Jul 27, 2013 | 06:28 PM
fmc400's Avatar
fmc400
MSEE
Does this vehicle have points, or electronic ignition?
Old Jul 28, 2013 | 06:15 AM
Chris Mullikin
Points. One little wire coming out from under the cap going to the coil.
Old Jul 28, 2013 | 10:04 AM
fmc400's Avatar
fmc400
MSEE
Got it. The wiring for points is pretty simple. Regarding the starter solenoid, a RED with BLUE stripe wire should go to the 'S' terminal of the solenoid. I would imagine you have this correct since the motor is turning over. A BROWN wire should go from the 'I' terminal of the solenoid to the positive terminal of the coil. The ballast resistor also goes from hot-in-RUN off the ignition key to the positive terminal of the coil. The negative terminal of the coil goes to the points and condenser in the distributor.
Turn the key to RUN. If the points are OPEN, you should see 12 volts at the coil. Check that as a first step.
Old Jul 28, 2013 | 09:08 PM
Chris Mullikin
Thank you for all the tips. After nearly three years my baby is running again.
Old Jul 28, 2013 | 09:17 PM
fmc400's Avatar
fmc400
MSEE
Awesome, glad to hear you got it worked out.
slour
Jun 10, 2017 09:04 PM
Sportsterengr
17
Apr 7, 2016 09:08 PM
oneminizut
151
Aug 26, 2013 08:26 PM
medicpg
Aug 9, 2007 11:25 AM
swooshcmk
May 25, 2002 09:18 PM
