That's definitely not a 6.0L in the truck, what other diesel's did they use?
Brazil supplies the Non-north american and non european corners of the globe. The brazilian production runs use an entirely different engine line, mostly the Cummins B-Series with varrying hp ratings depending on the year. The 7.3 was also available in most markets until late 2000's.
Things in these markets are much different than we are used to. They have all kinds of 4x4, and transmission differences than the State Side versions.
Reasons...most newer aircraft like this...28 volt eletrical system, 24 volt battery. Battery not easy to get to and the external receptacle requires a special connector.
