Starter
Old Apr 2, 2009 | 04:11 PM
61 uni's Avatar
61 uni
Starter
I was looking around under the truck this a.m. and I noticed the starter. Man that thing is small. Is is a high torque model or what? The one on my 4 banger s10 is bigger.
Old Apr 2, 2009 | 04:12 PM
superduty4x4's Avatar
superduty4x4
Huh? Mine's a big bastage.
Old Apr 2, 2009 | 04:15 PM
1996pwrstrk's Avatar
1996pwrstrk
Mines a big ole honk'n thang too.
Old Apr 2, 2009 | 04:22 PM
F250_'s Avatar
F250_
My first post in the thread linked below shows what my OEM starter looks like next to my new HD HiTorque starter from DB Electrical.
https://www.ford-trucks.com/forums/8...rter-envy.html
Old Apr 2, 2009 | 04:43 PM
61 uni's Avatar
61 uni
What does a db starter cost? They are about 30 min away. Might have to pick one up.
Old Apr 2, 2009 | 04:59 PM
rbi's Avatar
rbi
They must be too small. My truck goes thru them like fuel. 5 starters in 7 yrs.....not bad huh..
Old Apr 2, 2009 | 05:16 PM
ron's power stroke's Avatar
ron's power stroke
http://www.db-starter-alternator.com...1-06%20SND0355
Old Apr 2, 2009 | 05:23 PM
triskit16's Avatar
triskit16
Good lord...Ill knock on wood 1st but Im on the original starter...almost 10 years old!
Old Apr 2, 2009 | 05:24 PM
F250_'s Avatar
F250_
Might want to check ofr a dirty ground or a damaged hot supply wire. Too low of voltage can kill a motor prematurely.
I don't think you'll see that kind of "lack of performance" with the DB unit. That thing spins the engine like crazy. It has an extra tooth on the starter gear, which by itself increases spin. Then add to that the bigger motor. Sometimes, I almost think mine spins TOO fast.
Old Apr 2, 2009 | 05:29 PM
triskit16's Avatar
triskit16
Ill be goin with DB if mine ever goes out. 123 bucks vs 170 or so locally...no brainer...especially with their good rep around here!
Old Apr 2, 2009 | 05:35 PM
ron's power stroke
i expect one of these mornings when i hit the key..my truck will do the spining around rather then the flywheel..this starter is amazing in the dead of winter..
Old Apr 2, 2009 | 10:43 PM
jdecker88's Avatar
jdecker88
I really want one of them Cory has one on his truck and it spins over alot faster then mine but dang it is huge and it can hit your cross member if you goose it hard enough.
Old Apr 2, 2009 | 10:58 PM
jkidd_39's Avatar
jkidd_39
I have the DB high torque starter. I love it. I'll never get anything other!
Old Apr 2, 2009 | 11:08 PM
Ziggy.'s Avatar
Ziggy.
Yea it can, apparently even though I ground on the cross member, and allowed about 1/4'' or a little more room between them, when you get on it preeetty hard going up a hill passing a ricer trying to race you, the motor will torque enough for the back casing to hit the cross member and crack in half
Old Apr 3, 2009 | 08:57 AM
F250_'s Avatar
F250_
Originally Posted by Ziggy.
.... the motor will torque enough for the back casing to hit the cross member and crack in half
Wow... that's the first I've heard of that situation taking place. I only have about 1/8" clearance on mine, but it is also at a point where the motor housing is rounded, which I hope would allow some deflection of force. Even then, I guess the strain would still cause a problem at the next weakest link in its construction. I need to think about this some more.
