OE tire size?
Old Jul 24, 2013 | 06:55 PM
351Cleveland C4's Avatar
351Cleveland C4
OE tire size?
what was the OE tire size for a 2wd 71 f100?
im trying to figure out what speedo gear I need now that its got 31x10.50s... the truck has 3.25 gears.
as it is now, the speedo says 50 and im going about 40...
Old Jul 24, 2013 | 08:17 PM
HIO Silver's Avatar
HIO Silver
OEM tire size is G78-15. Translating that to a modern size tire and it's 215/75-15..... 27.6 inches in height.
I used an online calculator using the stock size and new tire size and the difference should only be 4.4 mph.
Old Jul 24, 2013 | 08:25 PM
351Cleveland C4
wouldn't I need one for a higher gearing?
and will putting an AOD in cause any problems? cuz that's in the works too..
Old Jul 24, 2013 | 08:27 PM
HIO Silver's Avatar
HIO Silver
Yeah, like 3.70s. I think you may have minsunderstood what I meant by final drive ratio.. it's acting like a 2.89 due to the larger diameter tires... long legs, less revs to maintain the same velocity.
Dunno about doing an AOD. Someone will chime in soon... wait for it.
Old Jul 24, 2013 | 08:45 PM
351Cleveland C4
but it has 3.25s now????
heres my train of thought,
3.25s with 215-75-15s would be correct speedo, but bigger tires = less rpm, the same thing as higher gearing. so a speedo drive gear that was for a 2.89 gear would be correct??
as far as the difference in speedo reading vs actual, yes it is only about 5mph, I confused myself. (again)
Old Jul 24, 2013 | 08:58 PM
HIO Silver's Avatar
HIO Silver
Derailed!
"Higher gearing" means lower numerically. Hence the final drive ratio acting numerically lower because of the increased tire size resulting in lower RPMs to maintain the same velocity (speed).
You need to speed up the speedometer, right?
Old Jul 24, 2013 | 09:00 PM
351Cleveland C4
I need to slow the speedo... or make the truck go faster to catch up, haha!
Old Jul 24, 2013 | 09:17 PM
Alex from GA's Avatar
Alex from GA
351, check how many 1/10s it's off in a mile and go to your friendly Ford dealer and tell him. Take your present gear with you. The freeways have mile posts.
Old Jul 24, 2013 | 09:27 PM
351Cleveland C4
haha, yea I need to do that too, but it doesn't quite run yet hahaha
I just needed the OE tire size to figure out my diameters. I can do the math and figure it out...
OLD TIRE DIAMETER X OLD SPEEDO GEAR / NEW TIRE DIAMETER =NEW SPEEDO GEAR
now I just need to know what my old speedo gear is, and I can find that out when I pull it loose...
this is just another drop in my glass of troubles...
Old Jul 24, 2013 | 10:19 PM
HIO Silver's Avatar
HIO Silver
Go here and enter your information: OnlineConversion.com - Bigger Tires
Old Tire Diameter: 27.6 inches
New Tire Diameter: 31 Inches
Indicated Speed 40 mph
Actual Speed: 44.92 mph
That means that the speedometer needs spin faster to state the actual speed.
Terminology is important. Let's speak the same language.
A "low" gear is numerically high like 6.69 first gear for the NP435
A "high" gear is numerically low like 1:1 for a four-speed manual.
Your truck thinks its final drive is 2.89, not a 3.25 anymore. Therefore, it needs to be tricked into thinking it's back to a 3.25 by using a speedometer drive gear that is for a numerically higher geared truck like a 3.50 or a 3.73.
Am I losing my mind on this?
Old Jul 25, 2013 | 05:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
DRIVE gear located on output shaft of trans / DRIVEN gear located at end of speedo cable.
Both are 'figured out' by trans type/axle ratio and tire size.
F100's of this era came with either 7 or 8 tooth DRIVE gears (obsolete) and 16 thru 21 tooth nylon DRIVEN gears (available from Ford).
To slow speedo down, add additional teeth. To speed it up, deduct teeth. Both apply to DRIVEN gear.
OP's user name contains C4, so if his F100 has this trans:
Old Jul 25, 2013 | 11:56 AM
JEFFFAFA's Avatar
JEFFFAFA
2X What Bill said. In addition to this I can tell you each tooth is between 4 to 6 MPH. Depending on the vehicle.
Old Jul 26, 2013 | 06:54 PM
351Cleveland C4
i do have the C4 in it now. but plans are for an AOD in the future.
Hio, yes that is correct, but my guage is reading fast now, I need to slow it down. I think you might be getting caught in my brain loop
I pulled mine loose and I have a 16T gear.
so according to jeffs 4-6 mph per tooth, to slow the speed meter aprox 5mph id need one with 17teeth right?
another wrench in the works may be that this tranny came from a torino... and the AOD that is planned from a 'stang
and where the heck can I find one of these? I seem to be having a hard time tracking one down...
Old Jul 26, 2013 | 07:46 PM
JEFFFAFA's Avatar
JEFFFAFA
Correct a mundo. Part number C7SZ17271A for a 17 tooth a/t gear. I have it here in stock at Berge Ford. I can
sell it to you at a wholesale price. PM me if you want it.
BTW, AOD's had 7 or 8 tooth Drive gears also.
TowPrincess
Large Truck
Mar 31, 2019 04:10 PM
scrooge
2004 - 2008 F150
Dec 4, 2010 01:33 AM
tpepper
Modular V10 (6.8l)
Nov 28, 2007 10:16 AM
70blue
Jul 27, 2005 08:30 AM
PRyan1983
Mar 3, 2003 09:26 AM
