Modular V10 (6.8l)
Tire size change
Old Nov 26, 2007 | 07:00 AM
tpepper's Avatar
tpepper
Tire size change
I'm thinking about going up in tire size to 32 inch tall tires from the the factory 31 inch size and was wondering what problems it may cause. Could any one comment with past experience? Thanks, Tpepper
Old Nov 26, 2007 | 07:50 AM
mackstruck's Avatar
mackstruck
Your speedometer will be a little slow, but not much. You can either live with it and be carfull not to get a ticket or pay to have it re-calibrated to the new tire size.
I just lived with it when I went up in tire size.
Old Nov 26, 2007 | 08:22 AM
tpepper's Avatar
tpepper
I read somewhere on here that it affected the computer causing it to run bad. Is this true? Tpepper
Old Nov 26, 2007 | 09:02 AM
jonrjen's Avatar
jonrjen
The difference between 31 and 32 is not great enought to throw off the CPU. There are a few websites that you could GOOGLE and enter the tire information and rearend ratio and it will give you the RPM, speedometer, and tire rotation differences if you care to have all the information.
Old Nov 26, 2007 | 09:47 AM
dkf's Avatar
dkf
You can have the computer reflashed at the dealer to compensate for the larger tires, should run less than $100. Another option is a tuner, but not every tuner can adjust for tire size.
My dad drove around for a year or so with his 33s before the dealer reflashed it, with no ill effects other than the speedo being off a little. I have 33's on my truck and I adjusted everything with my SCT tuner.
Old Nov 26, 2007 | 10:13 AM
tpepper's Avatar
tpepper
Thanks for the info. Tpepper
Old Nov 26, 2007 | 03:46 PM
armynavyguy's Avatar
armynavyguy
I have run 285/75/R16s (33" x 11.5") for 2.5 years without getting it flashed. I have no problems what so ever. I had a cop hit me with his radar gun while I was going 30mph and his radar said that I was going exactly 30mph. You might be a little off at highway speeds. I just drive like around 5mph slower on the highway to compensate.
Old Nov 26, 2007 | 04:16 PM
llcustom's Avatar
llcustom
You will be just fine, as said a 33" tall tire will make your speedo dead on. The speedo is a little on the fast side from the factory. So a 32" tall tire should put you right on or about 1 MPH slower than your speedo is reading.
Old Nov 26, 2007 | 04:55 PM
Big Orn's Avatar
Big Orn
Does the PCM ever know how fast the truck is going...physically?
If so, how?
Test tomorrow...
Old Nov 27, 2007 | 06:40 AM
Fredvon4's Avatar
Fredvon4
No the PCM does not have any other source about vehicle speed----except the data from the ABS computer where it gets the RAW speed signal pulses
The raw speed pulses are sent first from the differential tone ring to the ABS computer where they used to calibrate the actions of the Anti-lock brake system and the Seat Belt retractors and firing of the air bags
From the ABS computer the signal is sent "unconditioned" to the PCM
The speed signal is one of the most important sensors on these trucks
The PCM uses this signal for power train management and also distributes it "conditioned" to the dash cluster for use in the Speedometer indicator and also send it to the GEM for the speed adjusted volume controls of the radio (if equipped)
If you have an auto transmission the signal has a impact on shift points and line pressure strategy
The speed signal also has an impact on the emissions loop, ignition timing, and injector pulse durations
If the vehicle is a 05 and up with the Integrated Trailer Brake Controller (ITBC) the signal has a impact on the voltage sent to the trailer brakes
The factory can reset the REVs per mile within a certain limited range
Some chips/programmers can set to a wider range
A TrueSpeed module can set to larger range of revs per mile and hold two calibrations (say one for summer and one for winter tires)
I recommend having the Revs per Mile properly set in the PCM so all these sub systems can do their computations with a accurate set of data...just my 0.02
This is much more complicated then just having your Speedo read a little high or low
Old Nov 27, 2007 | 10:57 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I went to 285/75R16's over the summer, and found that the speedo is almost dead-on now - 61MPH at real-speed of 60.
But the odometer, it's WAY off now, around 10% too low.
I haven't recalibrated it ... yet. No issues...
Old Nov 27, 2007 | 09:27 PM
super 6.8's Avatar
super 6.8
I have always assumed that the odometer and speedometer were working hand and hand. I just put 285's on my 07 and using 60 miles of turnpike mile markers I calculated a 3.25 percent error in the odometer.
The reflash for 59.99 at the dealer asked for both revs per mile and tire size. Now the odometer seems spot on, but the mph....?
What is a good way to check other than have a cop use radar? A stop watch seems like a hard way to get very accurate.
BTW, my 99 was slightly fast from the factory and the 285's made it right on the money. But again, that was only an odometer check.
Old Nov 28, 2007 | 10:16 AM
krewat's Avatar
krewat
hand-held GPS works for me.
La-man
2009 - 2014 F150
Sep 15, 2016 11:28 PM
Codyaye
Oct 2, 2015 02:57 PM
MuddyFord18
Offroad & 4x4
Mar 28, 2010 09:44 AM
jcs1966
Jun 25, 2003 07:40 AM
bigFAWKINranger
Jul 12, 2002 01:58 PM
