the dreaded "wrench" light
Old Jul 23, 2013 | 09:35 AM
tbart16's Avatar
tbart16
While towing I experienced the wrench light which threw a couple of codes the first was under boost the second was over boost.
From what I have read on hthe site this could be serious but could it just be a sensor since it did over and under??
2006 6.0 auto 4wd CC DRW 99,000 miles
thanks
Tom
Old Jul 23, 2013 | 09:56 AM
npccpartsman's Avatar
npccpartsman
Specific codes?
Check MAP, EBP, and Baro values KOEO if you can, but it sounds like a sticking turbo to me.
Old Jul 23, 2013 | 09:58 AM
tbart16's Avatar
tbart16
truck runs fine until light came then I experience a severe lack in power. once I cleared code restarted and everything was fine
Old Jul 24, 2013 | 07:08 AM
tbart16's Avatar
tbart16
Your advice would be to tear down the turbo and give it a good scrubbing?
Old Jul 24, 2013 | 08:44 AM
Misky6.0's Avatar
Misky6.0
You realize 'clearing the code' doesn't restore normal performance?
The cause(s) of the codes remain - you just probably are not encountering the conditions you did before.
You would need an ODBII gauge reader (scangauge2 or the new apps for smartphones/MAC products) and be monitoring engine sensors WHILE towing to be able to identify what is happening at the time the check-engine lite comes on.
Before you do anything, you should monitor the sensors as asked by npccpartsman to determine a valid baseline - it's possible you have/had a bad sensor which through off the calibration on the turbo and resulted in your code..
It gets expensive to just try stuff based on the code, vs. finding out what the root cause that triggered the code was.
Old Jul 24, 2013 | 08:56 AM
tbart16's Avatar
tbart16
I have my edge wired in and am able to read codes on the fly. The wrench came on i pulled the vehicle over read codes cleared codes turned truck off and restarted truck and drove another 30 miles with no issues. Once the codes were cleared the truck was 100% again it ran like a champ. Drove truck yesterday with no issues. I was assuming sensor because of the fact that I had an underboost and an overboost code at the sametime. I will do some checking as npccpartsman reccomended thanks
Old Jul 24, 2013 | 09:15 AM
MisterCMK's Avatar
MisterCMK
How much boost did it make?
Old Jul 24, 2013 | 09:17 AM
tbart16's Avatar
tbart16
25 -26 enough to keep pulling my fifth wheel with no issues i have also my MPG dropped about 2 MPGs in the past month
boulderguy
May 19, 2013 03:25 PM
kidoo
Sep 19, 2011 07:26 PM
BRay09
Aug 6, 2011 08:18 PM
1Phatbasturd
Nov 12, 2007 02:02 PM
greenhedhntr
Nov 13, 2004 09:45 PM
