29 PSI - Wrench light - Overboost?
Old Sep 19, 2011 | 12:12 PM
kidoo's Avatar
kidoo
Hi, while pulling for about 10 second uphill at 29 PSI turbo on scangauge, the wrench light came on, limp mode, no codes, EOT 205, Water 197.
Could it be an overboost of the turbo? What limits the turbo?
Old Sep 19, 2011 | 12:45 PM
bismic's Avatar
bismic
It could easily be an overboost (depending on your software revision date) and you may not be reading the codes with a reader that can recognize the overboost code.
Old Sep 19, 2011 | 04:36 PM
kidoo's Avatar
kidoo
Should I get a revision of the software?
Old Sep 19, 2011 | 05:17 PM
bpounds's Avatar
bpounds
My '06 will hit 29# boost. I have the original '06 strategy.
If you are getting an overboost at 29#, then you probably already have the lastest strategy with engine protection.
If you got the wrench light, there had to be a fault code stored. How did you attempt to read the codes?
At this point, diagnosing this as overboost would be nothing but a guess.
Old Sep 19, 2011 | 05:21 PM
kidoo's Avatar
kidoo
I scanned with a scangauge II, I had no CEL and no codes. I restarted then it was OK the rest of the trip but I kept the boost below 28.
Old Sep 19, 2011 | 05:24 PM
bpounds's Avatar
bpounds
Do you know if you have had the PCM flashed within the last 1-2 years?
Old Sep 19, 2011 | 06:16 PM
kidoo's Avatar
kidoo
I do not know. But in march 2011, I went to three Dealers on my way down to Florida. They replaced the ICP that fixed the rough Iddle, the MAP sensor fixed the Wrench light and IPR fixed the cutting off on highway. May be they reflashed it, I do not know but they did all sort of test. I still have the bills, would it say it on the paper?
Old Sep 19, 2011 | 06:24 PM
bpounds's Avatar
bpounds
Originally Posted by kidoo
...I still have the bills, would it say it on the paper?
It might say it, or it might not. If they did the work under warranty, they are more likely to list it on the bill because they want to get paid for it. It would probably mention performing TSB 09-24-3.
Here is some reading on that:
https://www.ford-trucks.com/forums/9...-for-6-0s.html
The DTC for oil cooler efficiency is a newer one, and many code readers don't know how to handle it. But the code for FICM voltage and Turbo overboost have been defined for a long time, and are more likely to be recognized.
Your description of the issue sounds like overboost. We know it wasn't oil cooler efficiency because you were watching those temps. It does not sound like FICM voltage, because of when it happened. So it could be overboost, but it could also be something like excessive EGR flow or any number of things. You really have to know that fault code to have half a chance of figuring it out.
Old Sep 19, 2011 | 06:39 PM
69cj's Avatar
69cj
I had the oil and egr coolers replaced under warranty and all the receipt said was engine work. They also did stc and blue spring upgrade at the same time. I also checked the online record and it said the same. The bottom line did reflect the parts and labor.
Old Sep 19, 2011 | 06:48 PM
bpounds's Avatar
bpounds
If it is warranty, they are not required to itemize for the customer. I also had the oil cooler/egr cooler replaced under warranty, and they itemized some of it, but not all. Interestingly, they did not bother to reflash me, and so I am still running the OE flash.
If you can review your OASIS report at the dealer, it is more likely to show whether a new flash was performed.
I would think that with 3 different dealers trying to figure out problems during a single trip, one of them would have flashed it. Sometimes it seems like they do that whenever they are not sure what else to try.
Old Sep 19, 2011 | 07:01 PM
kidoo's Avatar
kidoo
I do not see the TSB code. What is the reason the engine would overboost anyway?
Old Sep 19, 2011 | 07:19 PM
bismic's Avatar
bismic
The Scangauge does not read all of the codes. Try an autoparts store for reading the codes - it might help.
Overboost could be a sensor issue (EBP or MAP again) or a sticking turbo (inlet guide vanes).
Chances are pretty good you were flashed to the latest software release.
An SCT tuner can read that software version.
How handy are you mechanically (ie pull and clean the turbo)? You might try pulling the MAP sensor hose and the EBP tube to see if they are plugged.
Old Sep 19, 2011 | 07:26 PM
kidoo's Avatar
kidoo
I will check the MAP. One thing I do not get is how the turbo works. Overboost, does'nt it mean it boost too much? To me it would mean it is a great booster!!!, but ... looks like it does'nt work this way.
As for mechanic, I can read and use wrenchs, it is just that I have to get minded to do it
tbart16
Jul 24, 2013 09:17 AM
shark1979
Aug 18, 2009 04:12 PM
strf12
Apr 29, 2009 05:06 PM
Sarge261
Feb 29, 2008 07:52 PM
Duksrule
Mar 7, 2005 05:31 PM
