open header damage?
Old Jul 22, 2013 | 12:54 PM
ddowell1's Avatar
ddowell1
open header damage?
Hey guys, just bought some headers for my 77 f250. It has a 400 in it and I dont drive it alot, but when I do I like to hear it. Ive read mixed things about running open headers some say it can warp valves, others say its just an old wives tail. Would just like a little more info on it thanks!
Old Jul 22, 2013 | 12:57 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Running open headers will tend to lean out the air/fuel ratio. Make sure the carb is set up right and it shouldn't be a problem.
Just glad you're not my next door neighbor.
Old Jul 22, 2013 | 01:22 PM
montana_highboy's Avatar
montana_highboy
X2 with Mike....
IMO open headers warping valves falls under the "old wives tale" category...
WWII fighter planes ran shorty headers, less than 12" in most cases, and they flew at altitude in temps upwards of negative 40-60 degrees.
If open headers warped valves those planes would destroy valves every flight.
Old Jul 22, 2013 | 02:11 PM
Poison Oil Racing's Avatar
Poison Oil Racing
have you ever seen a dragster/funny car/bracket racer with mufflers on their car?
I didn't think so.
Old Jul 22, 2013 | 03:43 PM
V10man's Avatar
V10man
I'd be worried about carbonmonoxide getting into the cab. Why not straight pipe it out to the sides?
Old Jul 22, 2013 | 05:55 PM
ddowell1's Avatar
ddowell1
I think thats what ive decided on, gonna put my headers on but im gonna run straight piping out to the bumper cant wait to hear what it sounds like
Old Jul 22, 2013 | 06:07 PM
fmc400's Avatar
fmc400
MSEE
You might, but those around you likely won't. Hopefully you live in a rural area.
I ran open headers on the way from my house to the exhaust shop and it was quite painful to listen to, especially at certain speeds where the sound seemed to create a resonant affect in the cab.
Old Jul 22, 2013 | 06:14 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Here is an idea when I first put mine on....and then later on did the "stack" thing with a quick one bolt and one u clamp mount system.
IT IS VERY LOUD IN THE CAB, CAN NOT TALK AT ALL IN THERE.
Would it pass inspection, well no. Has it ever had tags on it, well no...
But blasting out across the back 40, 4 wheeling and going thru the 4 spd you hear it for sure.
Old Jul 22, 2013 | 07:05 PM
V10man's Avatar
V10man
Be careful about up and over the axle bends if you have a shop do it with a ram style bender. I had 2 1/4" dual exhaust bent up and where they went over the axle was reduced to about 1 1/2". I lost all my power. Been there, done that, never again. Mandrel all the way & I go out the side now.
Old Jul 22, 2013 | 07:06 PM
ddowell1's Avatar
ddowell1
I do live in a pretty rural area, 5-6 miles separates us from the neighbors, and I think ive decided against the open headers but gonna run cutouts for truck shows and such
Old Jul 22, 2013 | 07:09 PM
ddowell1's Avatar
ddowell1
I will probably fabricate my own piping, as I have had that issue as well.....
Old Jul 23, 2013 | 02:13 PM
hivoltj's Avatar
hivoltj
No damage to the motor with a properly tuned carb afterwards. Will sound like *** though.
If you want a good loud sound without sounding like crap run 3" duals straight back to Dynomax Bullet mufflers and then out the sides in front of the tires.
Old Jul 23, 2013 | 07:18 PM
1972RedNeck's Avatar
1972RedNeck
Why not just run hood stacks?
Old Jul 23, 2013 | 07:33 PM
rogue40's Avatar
rogue40
Headers will hold enough heat so that the valves won't be affected.
It's when you run a motor without any exhaust piping at all (No manifold or header bolted to the head) that you run into problems. The exposed exhaust valves shock cool and warp.
Old Jul 23, 2013 | 07:40 PM
DeepRoots's Avatar
DeepRoots
If I may.....
at the track, a really well worked race engine with high compression sounds wicked with open headers.
A smogged out 150hp ford 400 with 7:1 compression in a F250 just sounds bad with open headers.
billy12360
May 25, 2008 06:14 PM
VX
Aug 25, 2003 11:01 AM
forddytube
Exhaust Systems
Aug 10, 2003 11:16 AM
