THEFT light chokehold on my Excursion
Old Jul 21, 2013 | 11:09 AM
charley_c's Avatar
charley_c
I have 02 Limited with 7.3 that I love but it will die then when I try to restart the truck it goes into theft mode and will crank but will not start. When I turn the key to on the position the THEFT light blinks rapidly for about 60 seconds, then blinks once then six times then starts over with the 1 and 6. If I disconnect the batteries it will usually reset and start. I took it to the dealer who told me it was a voltage problem and it needed a new alternator. I was skeptical do to fact the truck never failed to crank and I had measured both batteries at 12.96 volts. So I took the bait paid the $198 diagnostic fee, pickup a new alternator at NAPA on the way home, and installed it. The next day same problem. I read how the PATS cannot be the problem after the truck starts. If that's the case then why does it go into THEFT mode and not start EVERY time after it dies? It may run fine for a day or two then starts acting up again. If anyone has a solution or a similar experience please let me know.
Old Jul 21, 2013 | 12:59 PM
12valveEx's Avatar
12valveEx
Have you tried your spare key(s)?
Old Jul 21, 2013 | 02:55 PM
charley_c's Avatar
charley_c
Yes I have tried all three keys. It doesn't seem to make a difference.
Old Jul 21, 2013 | 03:15 PM
Misky6.0's Avatar
Misky6.0
If you have/had a remote start OR after market alarm it's possible there is a loose/cut wire not properly repaired. The PATS and improperly installed/removed remote start or alarms don't play well...
Old Jul 21, 2013 | 03:28 PM
charley_c's Avatar
charley_c
It is all factory except for two of the keys AAA made for me back in May. This started 4th of July.
Old Jul 21, 2013 | 03:34 PM
Misky6.0's Avatar
Misky6.0
AH. I believe you must have 2 PATS keys already in order to program more for your vehicle. I had spares cut and programmed by dealer when i bought my '05 ex 3has yrs ago.
Maybe PATS is detecting improperly programmed/duplicate keys from AAA?
Dealer also looked up door code for me.
Old Jul 21, 2013 | 04:14 PM
charley_c's Avatar
charley_c
Yes my 02 has the type B PATS which requires two keys to program using the keys. AAA used a computer for the two they cut. Then later on when I found my lost factory key I used the two new keys to program the old key and they all seemed to work fine for over 2 months. The Ford dealer supposedly checked the new 2 new keys when I took it in last week. The first thing the service adviser ask for was a second key.
Old Jul 22, 2013 | 10:21 AM
ithaca1230's Avatar
ithaca1230
Had a similar problem this winter. Ended up having bad batteries alternator and a Cam shaft position sensor. the altinator got fried cause the batteries were bad and it made the pats system activate and woldnt let the truck start real PITA!
Old Jul 27, 2013 | 01:15 PM
charley_c's Avatar
charley_c
Well after replacing the alternator and the still having the same problem I called the dealer to share my thoughts on their diagnoses.They asked for another try. After two days they had the truck running.The dealer said the cam sensor was the cause and that the tech had to remove the PCM and use a break out box to clear all of the codes. Evidently the sensor was almost crashing the PCM to the point the PATS could not comunicate with it. $348 and I am back on the road.
Last edited by charley_c; Jul 28, 2013 at 10:07 AM. Reason: Sorry left out the PATS
Old Jul 28, 2013 | 01:44 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Thanks a million for posting the conclusion to your problem!!!
Old Jul 28, 2013 | 10:15 AM
charley_c's Avatar
charley_c
So it sounds like was the same problem you dealt with ithaca1230.
Thanks to everyone one for all the reply's.
F350-6
Mar 9, 2026 10:19 AM
Fefanatic
Jan 15, 2024 11:31 AM
ryspin
2015 - 2020 F150
Apr 25, 2019 05:16 AM
FSJ-EARL
Jul 3, 2012 01:05 PM
Ryan50hrl
2004 - 2008 F150
20
Mar 12, 2009 01:12 PM
