Ford remote start
Old Apr 7, 2012 | 10:10 PM
F350-6's Avatar
F350-6
Ford remote start
This may be a long shot, but asking is much easier than doing tons of reading and trying to figure this out myself.
We recently picked up a 2000 EX with a 7.3 that has this installed
The seller made it work once, somehow. When we try to use the remote start feature the horn chirps and then the engine starts to turn over, but it wont start. I tried it sitting in the driver seat and noticed that the theft light was flashing when the remote start was turning the motor over. Using the key to start it, the theft light doesn't flash and the thing starts up just fine.
What am I missing? Any suggestions on what to check or do next? Why won't it start using the remote start, but it did at least once before?
Also, does anyone know how to, or what it takes to program these things? I'd like to change it so the glow plugs are on longer before the starter starts to spin.
There's also this
Since the older I get, the more I appreciate avoiding serious injury or death, can anyone tell me how to put this thing in service mode?
Old Apr 8, 2012 | 09:10 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
If your truck uses "chipped keys", you will have to hide a key near the steering wheel. They can program a new key with out cutting to match your locks, good luck!
Old Apr 8, 2012 | 10:34 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
To confirm this:
-Sit in the truck with the key in the ignition (off position) and remote start it
-If it starts fine, you'll need to program another key and place it near the PATS receiver near the ignition switch.
Old Apr 8, 2012 | 11:40 AM
pdombrowicki's Avatar
pdombrowicki
All the factory Ford remote starts I installed you never needed an extra key. They have a sense wire that wraps around the pats ring. Start your truck and then hit the remot start button, shut your truck off pull out the key and see if it stays running. If so you have a programing problem or broke wire.
Old Apr 8, 2012 | 02:34 PM
F350-6's Avatar
F350-6
Originally Posted by Toreador_Diesel
To confirm this:
I tried remote starting while sitting in the driver seat. It was a no go, but I did get several folks looking at me in the parking lot wondering if I was trying to steal it.
I'll try that and report back (after the rain)
Old Apr 8, 2012 | 06:05 PM
F350-6's Avatar
F350-6
Start your truck and then hit the remote start button, shut your truck off .
It stayed running. Is there a way to program this myself or am I looking at a trip to the dealer?
Old Apr 8, 2012 | 06:45 PM
pdombrowicki
Google search your part number and see if you can find the programing instructions. I don't have one.
Old Apr 9, 2012 | 07:56 AM
dsquared's Avatar
dsquared
Chris:
Here is the manual: Remote_Start_Installation_Guide and here is something else to check...
I have a dealer installed ford remote start (Eng P/N 2W7J-19G367-AA) - JustAnswer
Good luck!!
Old Sep 19, 2017 | 09:39 AM
Austin Hutchinson's Avatar
Austin Hutchinson
2w7j-19g367-aa
I have a 2004 ford excursion 6.0 with this remote start 2w7j-19g367-aa. It doesn't work and I believe it's causing some issues. Those being the radio turns on after I lock it with any remote factory or remote start. When unlocking with remote start remote it randomly flashes the running board lights and interior lights (after I stopped pushing the button it just keeps going) remote start doesn't work. I'm just looking to remove it but don't know how or if it'll mess anything up
Old Feb 7, 2026 | 11:58 AM
drtech's Avatar
drtech
7th Gear
remote start
Does someone have the install manual for a 2w7j-19g367-AA remote start 04 f350 6.0
Old Feb 10, 2026 | 04:42 PM
thor363's Avatar
thor363
You do not need to keep a key near this. There's a part number that's installed with that module. It's an ignition encircling ring that's used to detect key in. Part number for the ring that's likely already installed is:1L3Z-19G365-AB Ford PATS Interface kit
Edit: pop that cover and make sure the module is really plugged in within the main module.
Frankly I'd call the seller and just get them to relay how it works for you <OR> you'll have to do some reading. I downloaded the full manual from scribd at some point while I was accumulating the parts to install mine.
Old Mar 9, 2026 | 10:19 AM
thor363's Avatar
thor363
Anyone looking for this Excursion remote start kit?
https://www.ebay.com/itm/12772782889...8895&recoPos=1
jdunk54nl
Feb 22, 2021 02:46 PM
tfsiii
Jul 6, 2018 07:20 PM
Eightyfive Flareside
2004 - 2008 F150
Dec 7, 2016 10:26 AM
corzolek
May 3, 2005 04:07 PM
