Sponsored by: Real Truck
New owner needs help
Old Jul 16, 2013 | 06:03 PM
Marinathef250's Avatar
Marinathef250
Unhappy New owner needs help
I recently bought an 01 f250 4x4 with the 7.3 and 150k. It was not perfect but for the price I though it was worth my problem is that the ac clutch has gone bad and is screeching and started to smoke it's now parked and I can't even start it with out sounding likes it going to explode.
Question: can I remove the ac clutch and run the engine with out it. I would remove the shims and place the 8mm back. Is that a possible?
Thank you
Diego
Old Jul 16, 2013 | 06:20 PM
senix's Avatar
senix
Welcome to FTE, stand by I am sure someone will be along that can answer your questions.
Have you looked at the front of the motor under the hood for a diagram for the belt? Sometimes there is a diagram showing with AC and without.
Perhaps it is possible to buy a new belt using the alternate routing thereby deleting the AC out of the picture.
That is exactly what I did on my 92 Taurus.
Old Jul 16, 2013 | 07:40 PM
NewEnglandHerdsman's Avatar
NewEnglandHerdsman
Why not fix the AC?
Old Jul 16, 2013 | 08:04 PM
Marinathef250
Originally Posted by NewEnglandHerdsman
Why not fix the AC?
It's at a buddy's house 5 miles from mine and I'm going on deployment Monday. The answer is no you cant run it with out the clutch. The belt slips off
Old Jul 16, 2013 | 08:11 PM
senix's Avatar
senix
did you look at the belt diagram on the hood? A smaller belt may work.
Old Jul 16, 2013 | 08:25 PM
bubbasz1's Avatar
bubbasz1
My son and I replaces his AC clutch on his 2001 V10,little bit of finagling, a mirror and a 1/4 socket set and we did it, couple hours and under $100.00 from Advanced auto(we went with the cheap stuff) works great. Maybe you should check it out it might not be such a bad job.
Old Jul 16, 2013 | 09:17 PM
Marinathef250
Did not have the time to look into that but probably would have worked
Ended up buying the same thing it's just hectic preparing for a 10 month deployment moving out of my place in norfolk while the truck is in Miami. I will keep you guys updated
Old Jul 16, 2013 | 09:25 PM
azking_Ranch's Avatar
azking_Ranch
Have a safe Deployment
Old Jul 16, 2013 | 09:52 PM
Marinathef250
Thanks can't wait to get back to my new truck
Old Jul 17, 2013 | 05:43 AM
senix's Avatar
senix
Be safe, my oldest just arrived in turk for his 9 month or so. Second deployment to that area and he is infantry.
Old Jul 17, 2013 | 10:16 AM
NewEnglandHerdsman
Understood. Stay safe...
airmark
Jun 20, 2012 05:18 PM
XXL Supreme
Mar 9, 2007 12:17 PM
kidder
1983 - 2012 Ranger & B-Series
Dec 29, 2006 09:45 PM
joegeoghegan317
Jun 7, 2006 03:07 PM
Kenwood
Apr 22, 2004 07:04 PM
