AC on all the time>>>
04 F250 6.0PSD...
Ive had fits since new with a belt squeel... Ive had numerous belts replaced and tensioner and idler pullies and nothing has ever fixed it for lonnger than a week.. Now that its actualy warm out I noticed that the AC is Always ON I had the VENT only on this morning and noticed COLD AIR... so I turned the AC on and everything stayed the same... .. no matter where you turn the **** the AC is pumping away... So Im assuming BAD AC clutch... question is could this be the cause of my squeak squeak squeak as well.... Im really strating to have buyers remorse on this thing..
I cant believe Im in lemon law territory over the problems Ive had so far...UGH!!!
Originally Posted by Kenwood
04 F250 6.0PSD...
After having cycled from vent to a/c several times over the first 1000 miles it started working properly. I crawled up under it and had someone switch from vent to a/c several times and watched the compressor clutch lock and unlock as it should.
Originally Posted by FLFordOwner
you mean you have no climate control when your a/c is on?
Going into the dealer thursday for belt squeel and this again... Another few days of driving the loaner escort...LOL
Well... ins't the A/C on in most settings ?
this has been on other threads...
it has to do with humidity control.....
Maybe ford wants it on in some settings but I cant see a reason why they would have it on when Ive got the dial turned to the red section.. that makes no sense...Not turned to AC and pointing in red = no reason to have the compressor cycling in my book.... But maybe its a ford thing...If thats the case I better deactivate the HEATER they installed in my intercooler as well....LOL....
My 2004 had the sqeal also. I never took it in to determine what it was, however the ac being on/off had no effect. after about 2900 miles it stopped. Thank god, it was driving me insane.
Originally Posted by Fordtech1
Sorry guys, the 6.0L PSD uses the PCM to control A/C clutch switching, and has power to the relay in all positions except off!
FORD TECH>>>> so should I not keep bringing it in for belt squeel untill this bulletin is released???? or what..When exactly is later this year ??do you know???. The squeel is making me crazy... I hope the bulleting will get mine fixed and not just offer up a free pair of earplugs...LOL
Thanks for the input...I guess mine is normal then..
Properly operating systems will have the clutch engaged in MAX, NORM, and DEFROST. The A/C clutch relay is powered with key on, the PCM controls switching, based on selector settings. Malfunctioning selector input leads to PCM default control on.
Belt noise revision....late second quarter.
