My truck hates me for moving to Alaska
I've owned the truck for a couple months now (2000 F350 V10 with 210k). I checked the oil when I bought it: clean and full. Doesn't leak or smoke (until today) so I never really thought to check it.
Had it shipped to Alaska from Florida (military move). Picked it up the other day and all seemed fine. Second day of driving, the oil light came on and the gauge read zero upon startup. Shut it down, checked oil...and it didn't even read on the stick...WTF...it was 3 quarts low.
Now that its full, it still does the same thing for about a 1-2 minutes after startup, then the light goes off and gauge comes up. Been like that for a couple days now. Then today, after a short drive, I let it idle for a couple minutes and it started smoking. Goes away after a minute of driving down the road. Seems to be a greyish color...not blue like oil. And it doesn't smell like oil. Checked oil and level is still good. But, also noticed a kind of buzzing noise coming from the top, passenger side of the engine. Almost sounds like its coming from an injector or that area.
I took a couple quick videos to help explain. Any tips on where to start would be nice. Maintenance I've done so far is all new COPs, new Motorcraft Plugs (with one TimeSert), new PVC hose, and new air filter.
Well, to me the buzzing sound reminds me of a PVC valve buzz. It's the hose going into the valve cover you were filming.
Check the hose for cracks, pull the valve and start it up. Put your finger over the valve and see if the noise goes away. It will probably run like crap with the PCV valve out or plugged so don't worry about that.
unrelated question...does your exhaust stink without a cat....im thinking of cutting mine out and leaving the stock muffler
Here's a picture of what I have.
Not sure if this is all related, but I always had an odd noise from the y-pipe too.
Did you plug the pcv with your finger did the buzz go away. I would also check the whole hose especially if it was repaired at one time, maybe they didn't get it on all the way. If the valve is bad it could have been sucking all the time which would cause some oil usage. Hope the valve cures it for you.
Just played the video, answered my one question, hope the new one cures it but I would still check that hose just for good measure. Might want to check all the hoses, one for the IAC and I think there is one more, the truck ride mught have knocked one loose or a crack might have occured.
Fram oil filters are junk and sub quality. The oil issue on start-up sounds like the lack of an anti-drainback valve in the filter. The valve is to stop oil draining back into the pan and keep oil in the top end. Replace it with a Motorcraft FL820s and Im willing to bet that issue will go away!
