CHECK ENGINE LIGHT!!!
Old Jul 11, 2013 | 07:55 AM
frosty38506's Avatar
frosty38506
Exclamation CHECK ENGINE LIGHT!!!
OK, my check engine light comes on and the engine goes to idle only, push the go pedal and it stays at idle, won't do anything but idle for about 10-30 seconds then the light goes off and runs fine until it happens again....barely made it home last night, stalled like that about 6 times before i got home, i only live 5 miles from work... What can it be?????
Old Jul 11, 2013 | 08:53 AM
Tugly's Avatar
Tugly
Likely a Throttle Position Sensor, but you need codes or a scan tool to confirm.
Old Jul 11, 2013 | 11:16 AM
frosty38506
Thanks Tugly....Only place i have around here is the stealership.....limped it there / barely made it, they said it was the TPS, need to replace whole assembly... $500
Old Jul 11, 2013 | 11:20 AM
frosty38506
i am buying an AE once i recover from these added cost i'm having, after 2 trips to the stealership for scanning, 1 for injector issues and 2 for a TPS, i could have bought one..., $148 plus tax for diagnostic service.....
Trevor Whitten
Mar 21, 2019 05:29 PM
jed1894
Nov 25, 2015 10:18 AM
forresterdobbs
Oct 10, 2010 03:50 PM
bryan13
May 2, 2008 01:06 PM
short76
Oct 24, 2006 06:19 PM
