Inconsistent or rough idle
Old Oct 10, 2010 | 02:53 PM
forresterdobbs's Avatar
forresterdobbs
My truck is a 1993 F-250. 5.8L with 5 spd. Recently my truck was idling really rough and eventually it started shutting off completely. I changed the Fuel Pressure Regulator and it started running way better. Then shortly after the check engine light started coming on periodically. Now if I drive the truck down the high way or have my foot at the gas pedal at all the check engine light doesn't come on. If I stop and let the truck idle, the check engine light comes on. If I am driving down the highway and take my foot of the gas and let the vehicle just roll along, the check engine light comes on. Also, when I come to a stop the engine keeps running hard, as if I were reving the engine. If I lightly press the gas pedal the reving stops and the engine slows down as if to a natural idle. If I take my foot off the gas pedal the engine either goes back to reving, or else it begins to idle very very slowly and sometimes shuts off.
Any tips.
Thanks,
George Dobbs
Old Oct 10, 2010 | 03:50 PM
polarismuddman's Avatar
polarismuddman
Sounds like your TPS may need to be replaced....You need to pull codes and post up your findings. Go here Ford Fuel Injection How To Run a Self-Test
To test your TPS check out this writeup: http://www.f150online.com/forums/lig...ttle-body.html
carl2591
Jan 25, 2015 10:07 PM
c3racer2000
1978 - 1996 Big Bronco
Oct 11, 2011 01:26 PM
qball242
1983 - 2012 Ranger & B-Series
Jun 18, 2011 02:15 PM
sruiz2169
Dec 3, 2009 02:39 AM
Boxjockey
Nov 2, 2003 02:15 PM
