Temp 48 degrees.
Got the romps couple times but then started.
The idle jumped up a little I guess because to lower temp.
While the idle increased, engine light went off (right after the rpm jumped up).
Engine light off until I press the throttle just a tad and the light came back on.
Idle then stayed around 600 but fluctuated just a little to 700.
No codes on Scangauge.
Here are my readings from Scangauge
Are readings in normal range?
I think at idle, my ICP is in the 480-520 range, and the IPR is around 9.5.... I will try to remember to check when I leave work, and post up later. I see they are no longer listing ECT...
It completely depends on the EOT and the tune. You will get about 700 PSI ICP and 14% IPR at idle with a cold engine on a stock tune, and about 500 PSI ICP with about 10% IPR at idle on a warm engine with a stock tune. I have seen 575 PSI ICP with over 11% IPR on a chipped truck at idle when warm.
Romps - cold weather, old injectors and 15-40 oil are a recipe for romps. Synthetic oil (5W-40) is a common cure for cold romps on aging injectors - but other things can cause this as well.
