360/390 question
Old Aug 27, 2013 | 04:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by riverguideguy
theres a 4 digit code on the block behind the oil filter that montana_highboy told me about.
Mine is 4D10 which i was told means 1964 april 10.
4D10 date code on an FE engine block could also refer to April 10, 1974
If it is a 1964 engine, it would have an oil fill tube, rounded valve covers without holes for smog valve/oil cap, and...
Since 1958/64 FE engines were only installed in cars, a different block bolt pattern for the rubber insulators than was used 1965/76.
On sale day, 352/360 engines magically become 390's!
Casting numbers are foundry marks only, cannot be cross referenced to Ford part numbers, are WORTHLESS for identifying one FE engine size from another.
Since all FE engines were cast as 352's, what engine size do you suppose the foundry mark casting number refers to?
Old Aug 27, 2013 | 06:32 PM
69cj's Avatar
69cj
The only way to tell for sure is by taking a bore and stroke measurement.
Old Aug 28, 2013 | 12:42 PM
baddad457's Avatar
baddad457
The decade part of the date code can be determined by the casting number prefix (in most cases) There were no C4 blocks cast in 1974, so the date code would indicate a 1974 part. FE blocks were not all cast as 352's despite what is commonly found on the front of many FE blocks. Same thing applies to those blocks with "427" cast into them. Not all were 427's
GOT
Aug 20, 2011 05:25 PM
MagickNinja
Feb 23, 2010 11:30 PM
crazyh
Aug 26, 2005 03:13 AM
mallard8767
Dec 4, 2004 07:30 PM
ford390gashog
Jun 27, 2004 12:25 AM
