AE Class II - Troubleshooting
Old Oct 4, 2013 | 05:53 PM
  #76
cleatus12r's Avatar
cleatus12r
Butt-Head
I don't use AutoEnginuity, but here's an informative post from someone who does...A LOT!!
Ford Truck Enthusiasts Forums - View Single Post - whitesdford and milehi_350... AE readings
Old Oct 4, 2013 | 09:20 PM
  #77
jhand124's Avatar
jhand124
Originally Posted by cleatus12r
*Cough, Cough*
Close to, uh, five mS.
It is absolutely amazing that your injection pressure is where it is under those circumstances, T500 or not. But your injectors are empty by that time at that pressure anyway.
So the PW is off by a decimal right? It should be graphing a spike close to the top of the graph at 4.5-5 ms apposed to .45-.5 ms at WOT.
Which graph is my ICP amazing the towing one? What do you mean "your injectors are empty by that time at that pressure anyway."?
Just trying to learn more about the process.
Old Oct 4, 2013 | 10:07 PM
  #78
Tugly's Avatar
Tugly
Under normal circumstances, going over a 3ms pulsewidth kills the ICP. You have about a 4.5 to 5ms pulsewidth and yet your ICP is hangin' in there. Although I am not a tuner by any means, I have looked at enough of these things to know that your EGTs could be reduced (a little) if your PW was shorter. You would also see your ICP park at 3000 PSI at WOT and your IPR hover around 40%
According to the top graph (below), IH AC160s and stock injectors allegedly have about the same drain time - but I can't swear to that. If you can decipher the bottom graph, that is the flow characteristics for an off-the-shelf AC160... which is drained in 3.5ms at the ICP you are running. What that says is a stock injector or an AC160 is done long before the PW lets it's finger off the trigger... like a Windex bottle that no longer sprays after the squeeze-handle has bottomed out for a while.
Now... to shake up the sno-globe real good - I have 100% nozzles. They allegedly drain in under 2 ms at 3000 PSI, so a tune like that on my truck would conjure a cloud of coal an peg my pyro posthaste.
Old Oct 4, 2013 | 10:17 PM
  #79
cleatus12r's Avatar
cleatus12r
Butt-Head
Edit:
Misspoke.
A commanded pulse width of just under 3mS works well for those.....
Old Oct 5, 2013 | 07:44 AM
  #80
SaintITC's Avatar
SaintITC
Originally Posted by Nsaan
... He was saying that some older computers are having issues with them, that the USB's don't put out enough power and you will have it quit communicating in the middle of a session....
I have noticed this a few times myself, but had no idea why. Since you guys seem to speak to the AE people, ask them whether a "dual USB cable" would solve the problem? I doubt "dual USB" is the proper name, but I mean the USB cable that typically comes with external USB hard drives. It connects to two USB ports on your PC, but the leads combine into a single USB connection at the other end. Per the hard drive instructions, this is to allow the HD to draw more current through two separate USB headers.
Tom
Old Oct 5, 2013 | 08:01 AM
  #81
Tugly's Avatar
Tugly
Tom
That is a fantastic question, and I have one of those cables sitting to my left about 3 feet as I write this. There is one caveat to all of this: The OBDII interface is powered by the truck. I suspect our "guy on the phone" doesn't really understand what's happening in our cabs. The USB port doesn't lock like a LAN cable does... it is secured only by friction. Well... anybody with this era of Superduty will know the suspension doesn't "assist" a friction-secured connection - think UVCH with a lock tab that fails. The most common problem is a weak grip on the USB port and you get noise in the power and the signal... or it just cuts out. AE will not try to restore connection when this happens, so all your data windows go to zero and you have to reconnect manually.
Old Oct 5, 2013 | 08:07 AM
  #82
SaintITC's Avatar
SaintITC
... The USB port doesn't lock like a LAN cable does... it is secured only by friction...
And there's a fix to this if you like. Just wrap the USB cable around the AE connector and tape it in place, this way it vibrates together. If you're really interested is making it secure and look a bit neater, a tiny shot from the Buck$Zooka can get you a USB cable which is angled at the end (in any of the four directions you'd like), so it's easier to secure it closer to the actual connection.
Old Oct 5, 2013 | 08:35 AM
  #83
Tugly's Avatar
Tugly
...a tiny shot from the Buck$Zooka...
I have a Quarter Caliber for such purchases... faster reload time.
Old Oct 8, 2013 | 07:59 PM
  #84
pwhite144's Avatar
pwhite144
No Start Recording
Hi Tugly,
Great thread, I have learned a ton about AE already. I wonder what you think of this one? I have a no start issue. ICP shows plenty of pressure, RPMs are good, Voltage nominal, IPR Duty cycle is ok (I guess?), but the PCM won't lengthen out that Injector Pulse Width. I'm at a loss as to what is causing this and I hate to start replacing costly parts. CPS is new also. Don't want to hijack the thread. It's another teaching tool anyway. (changed to .txt extension for the upload)
Thanks for all the info!!
______________________
Paul
2000 Ford F-250 Lariat Ext-Cab 7.3 PSD
DP-Tuner F8 w/ 80HP "Econo", High Idle, and Stock tunes
Napa 6637 Air Filter
EGT and Trans Temp gauges
Old Oct 8, 2013 | 11:24 PM
  #85
pwhite144's Avatar
pwhite144
Tugly,
I may have figured out why that Injector Pulse Width is so narrow...fuel pump isn't pumping consistently...or at all at the moment. Does the PCM sample fuel pressure to decide about IPW? I was under the impression that it doesn't, but my numbers appear to be saying something else.
I'll post my readings after the new fuel pump tomorrow...I sure am hoping to see that pulse width suddenly lengthening!
Old Oct 9, 2013 | 03:53 AM
  #86
Tugly's Avatar
Tugly
Your FIPW is reading fine. The problem is your AE is buggering up the translation of it. Here is how you fix AE's bug: [LINK]
The PCM has no idea if there is fuel or not, it just tells the motor what to do and hope the fuel is there. That is precisely why I urge a fuel pressure gauge is a must-have on our aging trucks.
Old Oct 9, 2013 | 09:59 PM
  #87
pwhite144's Avatar
pwhite144
Thanks, Tugly
I changed the parameters and fooled with a few of the others. The fuel pump solved my problem and I ordered the fuel pressure gauge today. Sure wish they would have put that into the PCM equation, but I really can't complain much about such a tough engine.
I monitored and recorded a good bit of data, only to learn that when the computer sleeps, the file sleeps with the fishes.
I did notice that #8 has a 5% change in rotation compared to others. At this point I'm just glad to hear that growl, but may be something down the road. The cylinder contribution test also showed #8 not keeping up. I'll check it again after a few days of driving just in case it is air in the system.
I'll try to record again and post for the benefit of the class and one more example.
Thanks again!
Old Nov 22, 2013 | 12:46 PM
  #88
SaintITC's Avatar
SaintITC
Tugly,
I posted earlier about running cylinder change rotational velocity (perdel) tests. Not sure if I'm running it correctly or not. My AE only offers choices for cylinders 2 through 8, and then, according to the Live Data Grid where one would adjust ranges, it says No Data for all of them. I'm getting straight zeros, and occasionally it hiccups (I have a cheapo CPS in her now).
I'm guessing I've either got something setup wrong with my PC and/or AE, or ???
Any help would be appreciated, or should I post a question directly to AE?
Thanks,
Tom
Old Nov 22, 2013 | 05:33 PM
  #89
JT250's Avatar
JT250
You have to be stopped . it will say 0 while driving. You should be able to see all 8.
Old Nov 22, 2013 | 06:11 PM
  #90
SaintITC's Avatar
SaintITC
Parked in the driveway, reads 0. My concern is the Live Data grid where it says no data, and no selection for #1. It's a manual transmission, in neutral, should I depress the clutch. There are a few other issues with AE, i.e. vehicle speed never reads anything either.
