Infinity boost ?
Old Jul 4, 2013 | 10:31 PM
4wheeling79's Avatar
4wheeling79
Infinity boost ?
Is adding a boost signal to the Infinity a option? Or does any one here know how about doing it? I would really like to have it on my screen so I can watch it.
Old Jul 5, 2013 | 05:24 AM
Tugly's Avatar
Tugly
You would want Manifold Absolute Pressure (MAP) PSI. You're looking for "Gauge", "Indicated", or something similar... but not "Absolute".
Old Jul 5, 2013 | 10:44 AM
4wheeling79
Yes exactly I don't want to monitor the MAP sensor. Does any one know how to add a sensor to the Infinity?
Old Jul 5, 2013 | 11:33 AM
diehardstroker's Avatar
diehardstroker
Theres at least one maybe 2 ports in the back for electrical sending units. I would pm justin@dptuner and he will be able to tell you if you can add boost to it
Old Jul 5, 2013 | 01:31 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
If you want to monitor boost without having to subtract absolute pressure from MAP, you will be looking for the parameter called Manifold Gauge Pressure(MGP).
You may also add an external 0-5v pressure sensor/sender. We recommend using Autometer sensors if you plan on doing this. If you have already purchased the EGT setup from us, then you already have the cable that it takes to add/connect another sensor to the Infinity.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Robert Green
6.4L Power Stroke Diesel
Dec 1, 2017 01:16 PM
Kdawg89
Aug 3, 2015 05:07 PM
mikec91
16
Apr 19, 2013 12:26 PM
ehgeeray
Feb 1, 2010 03:06 PM
Rodeohauler300
Mar 26, 2007 06:35 PM
