Reading Boost
Old Feb 1, 2010 | 02:54 PM
ehgeeray's Avatar
ehgeeray
Reading Boost
I understand that if you want a analog boost guage you probably need to install a boost sensor. Can you read the boost pressure from the PCM if you have a digital guage?
Old Feb 1, 2010 | 03:06 PM
william_04_x's Avatar
william_04_x
You can get a reading from the MAP sensor and read boost through the OBDII port with a digital gauge.. My little ScanGuage II has a MAP readout available, but it's not in PSI.. Edge brand boxes read digitally and output in PSI..
