460 banks power pack
I just had the Banks exhust system put on my 1993 460 e40d truck. I'm glad I had it installed by my mechanic, there were 4 broken bolts removing the old exhust. I also installed the banks trans command myself- (easy). I did notice better acceleration driving it home, and i went from 11.5 to almost 13 MPGs-- but the real test will be towing my trailer in 2 weeks, 8800# and 32 ft long. (The reason I bought the Banks exhust). I hope it lives up to the numbers they (Banks) claim it will add to the truck.
There is no 'chip' for your truck. If you are so inclined to do computer mods, you would need to buy the proper softwear to tune your efi. Probably more effort then you are looking for.
As for the Banks kit, you may be able to assemble a 'kit' like it for cheaper with off the shelf parts, but you may pr may not see the same numbers as they advertise, as they may well be 'matched' parts for te application.
I had the banks stinger pack on my '97 460, it's the same as the power pack but doesn't have the headers. didn't really like the exhaust much because it was as quiet as stock.
Jet chip does make a chip for EFI 460's. You have to use premium gas or it will ping though.
Troyer performance makes under drive pulleys for EFI 460's. I have a set and really like them.
Here is a thread on the 460ford forum for more info on EFI 460 mods: 97 460 efi - 460 Ford Forum
