Correct MAP readings from AE?
Old Jun 28, 2013 | 08:03 PM
cutlass's Avatar
cutlass
I'm going through my list to see what might be causing my trucks issues and I was looking at the Intake Manifold Absolute Pressure on AE and at idle it is at 14 psi while exhaust back pressure psi is about 14.5. When drive the truck around, the value for the MAP runs anywhere between 1 and 4 psi below the exhaust back pressure.
Does all sound well?
Thanks,
Drake
Old Jun 28, 2013 | 08:34 PM
Tugly's Avatar
Tugly
The MAP needs to be very close to the EBP with KOEO, but EBP will always be higher than MAP with the engine running. EBP drives the boost, and MAP is boost... so MAP has to be lower because of efficiency losses.
Old Jun 28, 2013 | 08:50 PM
cutlass's Avatar
cutlass
Thanks Rich. Just trying to find a smoking gun here.
Can you direct me how to diagnose the proper operation of the IPR via AE?
Thanks,
Drake
Old Jun 28, 2013 | 09:11 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Well, you can watch what the PCM is commanding.......
There isn't anything you can "see" about proper IPR operation with a scan tool. You can see what the PCM is commanding the regulator to do in response to what actual vs. desired injection pressure is and that's about it. Whether the pressure regulator is actually doing anything in response to that command is another story.
Old Jun 28, 2013 | 09:14 PM
Tugly's Avatar
Tugly
The last couple of links in my signature has some good stuff. Give 'em a click.
https://www.ford-trucks.com/forums/a...9&d=1371720855
Old Jun 28, 2013 | 10:36 PM
cutlass's Avatar
cutlass
Thanks Rich, this helps me understand the HPOP operation much better.
Drake
SRBF150
Aug 8, 2015 06:56 AM
hydro man 17
Jun 27, 2013 07:28 AM
AndeyHall
Jul 22, 2010 11:35 AM
carlsson
May 15, 2008 05:20 PM
79_250RangerLariat
Mar 12, 2008 05:05 AM
