MAP Reading
Old Jun 26, 2013 | 01:07 PM
hydro man 17's Avatar
hydro man 17
MAP Reading
Was just fumbling around with the AE and came up with a MAP value of 26.2-3 at ~ 3500 ft elevation. Is that about correct?
Mike
Old Jun 26, 2013 | 01:25 PM
01PS's Avatar
01PS
Looks good from my reference.
Old Jun 26, 2013 | 04:09 PM
Shake-N-Bake's Avatar
Shake-N-Bake
MAP is Manifold Absolute Pressure which is equal to Barometric Pressure plus Boost. If the engine is off and your unit of measure is PSI then you should be reading around 13 ish.
Old Jun 26, 2013 | 04:40 PM
hydro man 17
Thanks for the replies. Engine was running at idle.
Old Jun 26, 2013 | 04:52 PM
Shake-N-Bake
Then you might see one or two tenths PSI lower than Baro.
This is because there is no boost present at idle but there is a little bit of vacuum in the manifold.
If you are reading 26.3 psi at idle then something is wrong with the sensor or your calibration has modified the look up table for that parameter.
Old Jun 26, 2013 | 05:00 PM
01PS's Avatar
01PS
My apologies, I was looking at Baro pressure in In Hg. Shake n Bake is correct, should be 13ish PSI.
Old Jun 26, 2013 | 05:11 PM
hydro man 17
I just found a comparison chart and (hopefully) my AE was reading inches of mercury, which at 3500 ft is dead on at 26.3. Truck runs great with no issues other than #6 glow plug problem, which is why I had it hooked up in the first place to check the CEL
Old Jun 27, 2013 | 07:28 AM
Tugly's Avatar
Tugly
Key On Engine Off readings: Look at your Exhaust Back Pressure PSI absolute and your MAP PSI absolute... they should be within a few 10ths of a volt to each other.
SRBF150
Aug 8, 2015 06:56 AM
indyraven
Jul 9, 2014 01:47 PM
cutlass
Jun 28, 2013 10:36 PM
AndeyHall
Jul 22, 2010 11:35 AM
79_250RangerLariat
Mar 12, 2008 05:05 AM
