CPS
Old Jun 23, 2013 | 08:19 PM
1L243's Avatar
1L243
CPS
I am thinkng I would like to carry a spare cam posistion sensor. I have a early99. Should I get it from Ford or would Napa after market do? Part number
Old Jun 23, 2013 | 08:24 PM
JWC 3's Avatar
JWC 3
Only buy a Ford or IH sensor . Ask me how I know ....
Old Jun 23, 2013 | 08:30 PM
Crewcab Turbo's Avatar
Crewcab Turbo
Here is the International one.
Old Jun 23, 2013 | 08:31 PM
snakedoc's Avatar
snakedoc
X2 ONLY FORD OR INTERNATIONAL.
Clay and Bob have the best price.
International makes all of them for Ford so ether is good.
Old Jun 23, 2013 | 09:15 PM
Stewart_H's Avatar
Stewart_H
There is another option out there, according to this post:
Originally Posted by TARM
I know this is an old thread but wanted to update a fix I used for the wiper issue with the BWD CPS as well as others causing stalling or stubbling. Apparently, the issue is trash interference from the wiper motor which is magnified on intermittent setting. This can actually happen with all CPS but some are more sensitive than others. The wiper motor according to TPS is going bad. THe "correct" fix is to repalce the wiper motor. IMO a good fix until the dam thing dies, if ever, is to cut the ground wire coming from the wiper motor which happens to use the same main ground wire as the PCM and few other things which is why it causes the issue. Cut the ground wire and then rewire it to its own ground somewhere else.
All I can say is this fixed the issue in one truck a friend had the issue with and was also a suggested suggested solution I read in a TPS. This should allow people to use the BW as well as I think people had issue with the bosch unit and others as well from this.
The issue with the Ford and IH new CPS, as well as it seems every one I have seen cut open that has the recessed or stepped in end instead of the full sized housing to the tip of the unit, is the plastic end is about 3/16"-1/4" thick even a tad more and the hall sensor itself is actually off set a bit (about 1/8")
The original Ford/IH (blacks), BWD, and the Delphi units that had the large ends seems to all have the halls sensor directly in the center. The end cap plastic was so thin that the hall sensor actually caused a protrusion that can be seen if you angle it in good light (like a ghosting image). Further when you test the magnetic strength at the tip by pickup up different weight objects the ones with the larger housing, thin cover, and centered halls all are significantly stronger, picking up heaiver items.
Consider what the effect is of having two units both with the same over all length that they protrude into the front cover to the cam gear but one has the actual sensor 1/4" farther away because of the extra plastic so the sensor is actually deeper into the CPS than the one with it right at the the surface.
Then consider what the effect of sloppy placement of the hall sensor does so that it is no longer centered but slightly off set. This has the same effect as changing the time of SOI (start of the injection). 1/8" offset equals about a 2.4 degree change in timing if it consider a tangent off centerline. Adjusting timing that amount in a diesel or gas for that matter has a significant effect. It would be one thing is the engine was some how updated for this change or the engine was setup for the specs of these new sensors. The issue is it was setup for the original sensors. That means a centered sensor. That sensor was suppose to be what .25-.30 off the cam gear. If the plastic cover itself on the new ones is .25 thick it would almost have to be touching the actual cam gear to be at the correct distance. Not even taking into account its not centers up as it should.
This is all from a collection of reading what others have found and some testing I did. IN no way do I take credit for all these findings I just wanted to put them in one place for everyone here as I know these CPS are frustrating. They are one of the the most critical pieces to our engines performance. Without it there is no timing for fuel, knowing rpm, diagnositc trouble shooting etc. All of the various systems accuracy is based off accurate readings from the CPS. SO if its not perfect nothing based off it can be.
So what you want is a unit with the larger housing end. The hall sensor centered and the thinnest amount of plastic covering the hall sensor on the tip end. If the plastic is thin you should get a slight impression of the hall sensor when you angle it back and forth in the light. THe color of the aftermarket sensors is meaningless do not refer to any by color. It will only screw you and everyone that reads it up. Take the BWD. They were black now they are grey. But everything is the same only the color of plastic changed as it was likely a cheaper cost for it. Further you can not just rely on names either IMO you need to look at the sensor if you can before buying them or check with other than have in relatively recent time. Delphi I purchased from Advanced Auto came as identical to the ford upgraded ones that all call the greys. It was also grey in color. It no longer had the full sized end and had the same weak magnetic strength. Total crap. Either they have changed design or had a shortage and bought from the same manf Ford used. SO maybe this will change back or its only some in circulation but I know of at least one more that reported the same thing from a amazon online purchase.
So moral of the story is have the CPS is hand and make usre it has the large end and if you can try to see the hall sensor ghosted imprint on the end.
A drill bit will also tend to roughly center to the center of the magnet of the hall sensor. But all the large end ones from Delphi (delphi now has small end ones out there as well, be careful) and BWD have been perfectly centered and very thin plastic covering.
I put dielectric grease in and around the connector to ensrue no moisture issues.
What amazes me is that Ford has the gall to call these failures on contribution tests and perdels that spike on numerous cylinders as nothijng but phantoms. Sorry but it measures electrical inputs exactly how is that phantom of anything. Its total BS to not have to be responsible for another 1 million unit recall on 10+ yr old vehicles. They are getting these readings because they used cheapo manf tolerances and design. It clearly has an effect on the engine no different than adusting the time by 2.4 degrees on a gas engine would. Duh That is just from the offset which I bet can vary as well. Then missed pickup of teeth from the fact the magnet is about 1/4" farther away from the cam gear than it should be. Then take into account wear variations in the various engines out there. Some will obviously be effected far worse than others. But this is anything but phantom issues that the PCM or CPS is somehow sending out. There is no way my basic brain is smarter than those ford techs at corp so its a real good bet they know this quite well.
All I can say is after swapping in the BWD last night after having the newer ford one in there its night and day difference in smoothness. Both at idle as well as when driving. My drive is very consistent and the idiot meter normally once I get 100 miles on it does not move even 0.1 mile for avg mpg. Today I had to drive back and forth many times and put on another 100 mils. The gauge moved 3 tenths already.
For my wipers I had not issue that some have with wiper motor causing issues. I was almost hoping it would so I could do the mod on the ground wire to see it work on my truck as well. Just another confirmation is all I was looking for.
Thread found here: https://www.ford-trucks.com/forums/1...l#post11561465
Stewart
Old Jun 23, 2013 | 10:11 PM
JWC 3's Avatar
JWC 3
Wiper motor ? Interfering with CPS signal ? I can go with that . I have seen stranger . I recently had a ranger ,3.0 98 or so , brought in for a no engine shut off ! Turns out the headlamp switch was bad ! It was backfeeding to the cluster and GEM keeping the ecm relay lit with key off !When I took it apart I ended up getting a whole cluster surround and a new switch . The PO had done his repairs with super glue and sheet rock screws ! After replacing the headlamp switch , the truck shut off at key off . Explain that to your customer !
Old Jun 23, 2013 | 10:19 PM
snakedoc's Avatar
snakedoc
my brothers ranger would light both blinkers when you right turn, all it was was a bad ground under the main fuse box. stragn things can happen,
i did not list the BWD as i have not seen a fix to the the wipers.
Old Jun 23, 2013 | 10:29 PM
Stewart_H's Avatar
Stewart_H
Wipers interfering with CPS function has been a well documented symptom for quite a while now.
Stewart
Old Jun 23, 2013 | 10:50 PM
JWC 3's Avatar
JWC 3
Stewart
I am happy to learn that ! I have not seen that issue before . In my shop we work on most makes ( independent shop in business since 83 ) The owner is an old Massey tech , I've been there 12 years . I just worked on an 08 550 pulling and cleaning the tank for bad fuel , and just delivered an 87 Porsche that I preformed $4900 of work on . So ... I work on a lot of makes . Harvest season is not far away, I will be working on combines and more tractors soon !
Old Jun 23, 2013 | 10:58 PM
Stewart_H's Avatar
Stewart_H
Check this out! I actually used my wipers as a diagnostic tool to determine my CPS was going bad when I developed an occasional hiccup when driving down the road.
Stewart
Old Jun 23, 2013 | 11:19 PM
JWC 3's Avatar
JWC 3
Stewart
I shall remember that ! And try it .
Old Jun 23, 2013 | 11:25 PM
JWC 3's Avatar
JWC 3
Tried to rep you Stew , but could not at this time , sorry .
Old Jun 24, 2013 | 03:12 AM
Crewcab Turbo
I recently picked up a BWD sensor and have the windshield wiper problem with it. I have not found any info on exactly where the ground wire is located that needs to be separated. Is it buried in the harness? Does the harness need to be cut open to find it?
Old Jun 24, 2013 | 11:37 AM
hydro man 17's Avatar
hydro man 17
I installed the BW unit a while back and no issues so far. Idles smoother than Ford recall unit ( not perfect but no hutch mod yet) and first fill up with 1.5 / 2 MPG gain. Hand calculated and combo driving around town as well as some 6% grades.
12 pointer
Jul 24, 2012 09:19 PM
f350ford17
Mar 29, 2012 10:05 AM
deputy
May 3, 2011 01:58 PM
jimwilsonmasonry
Mar 15, 2008 09:28 AM
mauleace
Nov 5, 2003 03:45 PM
