which turbo do i have?
Old Jun 18, 2013 | 09:30 AM
chafer's Avatar
chafer
This is getting frustrating. Ordered a turbo though a local diesel shop, came in and it was wrong, no wastegate and 3 bolt exhaust flange, They are now telling me I have an rare truck that is a 1998 F350 and cannot get a turbo upgrade for it. Looked at the beans site and it appears that there early 1999 turbo also has no wastegate and a 3 bolt exhaust flange. My truck is registered as a 1999 but was built in 1998. The turbo in it has a wastegate and the exhaust flange has more than 3 bolts. HELP don't want to get stuck with another restocking fee! Can anyone help me identify the turbo in my truck?
Thanks in advance
Colin
Old Jun 18, 2013 | 10:12 AM
mueckster's Avatar
mueckster
Does it look like this? Ford Turbo Charger F81Z 6K682 Aarm s 12 5 | eBay Early '99's have 1.10 A/R on the compressor housing at the spider end and have a wastegated turbine housing.
Old Jun 18, 2013 | 02:32 PM
chafer's Avatar
chafer
looks similar, no data tag place on mine by the garrett logo and garrett is more to the left in bigger letters ? Mine does have the wastegate built into the housing, not bolted on.
Old Jun 18, 2013 | 02:43 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Go to a new shop. There is no such thing as a 1998 F350. Flat out doesn't exist. Ford didn't make them. No it's ands or buts.
You probably have an early 99 model.
Old Jun 18, 2013 | 02:53 PM
acf6's Avatar
acf6
^what he said. It sounds like an E99, even if the build date has 98 in it, its still a 1999. Ford was switching over production lines from OBS to super dutys in that time. Time for a new shop...
Old Jun 18, 2013 | 02:58 PM
chafer's Avatar
chafer
early 99 then. Ok, so the real question is then, is there a bolt in turbo upgrade available? that will bolt up to my MBRP exhaust flange? and will eliminate the bad turbo pulse I have when pulling my trailer up hills?
Old Jun 18, 2013 | 03:05 PM
tappit01's Avatar
tappit01
Early 1999 Power Stroke BDP Dominator 66 Turbo - Single Turbo Kits - Turbo - Performance
Old Jun 18, 2013 | 03:45 PM
12pump's Avatar
12pump
What's wrong with your turbo? Have you concider rebuilding it? It sounds like you want to go with a wicked wheel or second generation wheel to get rid of surge?
Old Jun 18, 2013 | 04:09 PM
chafer's Avatar
chafer
not sure what is wrong with it, surges bad under load, trailer is heavy (11000lbs) and truck has 300000km on it. Thought upgrading was the best bet, already have exhaust, intake, and DP tuner. just don't want to order a second wrong turbo, will call beans tomorrow, the pic on their website shows the early 99 turbo with no wastegate and a 3 bolt exhaust flange. mine stock one has at least 6 bolts maybe 7 and a wastegate built into the housing
Old Jun 18, 2013 | 04:30 PM
sledhead999's Avatar
sledhead999
Does your turbine housing look like this?
http://www.riffraffdiesel.com/mm5/me...e=F731-TRB-HSG
Old Jun 18, 2013 | 09:14 PM
Pitcrw6's Avatar
Pitcrw6
Clay at riffraffdiesel has the whole kit for upgrading from a E99 to a L99. Has great customer service nobody can beat. You said you have a DP tuner, do you have any gages to monitor EGT, tranny temp and boost? Those are highly recommended if not a must when towing.
Old Jun 19, 2013 | 12:46 AM
duck fan's Avatar
duck fan
Because racetruck
+1. Call Clay at Riffraff in the morning. He's had a couple E99s and really knows his stuff. He'll get you pointed on the right direction.
Old Jun 19, 2013 | 04:53 PM
chafer's Avatar
chafer
mine has 1.00 A/R on the compressor housing
Old Jun 19, 2013 | 05:05 PM
chafer's Avatar
chafer
if I can figure out how to post some pics on here I will. The compressor housing says 1.00 A/R if this is any help
94_IDI
22
Jul 2, 2013 08:58 AM
rat49f6
22
May 16, 2013 08:51 AM
cutlass
Feb 13, 2013 06:56 AM
Awitte58
33
Apr 4, 2012 03:42 PM
shanett306
Feb 5, 2007 10:21 PM
