I like it Jim! But with the SD intake housing won't you have to change plenums? Unless I guess you're inter-cooled already in which case you could just change the hot side pipe.
Ok, I see now. I didn't realize the SD turbo you used was an e99. That makes sense. The e99 turbo is pretty close to the OBS turbo anyway so I assume the main improvement of this setup would be the ease of removal correct?
Damnit you beat me to it... I've been wanting to try this for a long time now.
Question- what did you do with the EBPV? And did you try just swapping out the center section and pedestal and keep the OBS intake housing?
I knew someone had mentioned it recently so I went ahead and tried
I havent got to mount it to the pedestal or back on the block yet so I wont know about ebpv until later
The obs center section seems to have a slightly diffrent pattern where it bolts to the compressor housing ...I tried the obs housing one the e99 center section and it woukd not bolt up
