Aerostar Ford Aerostar
Need Help!!
Old Jun 15, 2013 | 09:01 PM
terbear2910's Avatar
terbear2910
Need Help!!
I had to put new brake lines on my 91 Aero and when i started to bleed the brakes. The driver front line had not fluid coming through? Is there something that could be causing this?
Old Jun 15, 2013 | 11:27 PM
96_4wdr's Avatar
96_4wdr
Brake flex lines syn. rubber compound breaks down, flakes off and plugs lines and brake caliper fluid holes.
or:
master cyl. is leaking by from front brake section to rear brake section internally.
any brake fluid coming out bleed screw on either front caliper?
Old Jun 16, 2013 | 07:52 AM
Kruse's Avatar
Kruse
Did you put a new line on the driver's front, or was the new line installed elsewhere? Just a couple of days ago, I replaced a front line on my '97 F250 because the line had internally collapsed. The front, right line would allow the brake to apply pressure and wouldn't release. A new line fixed it and it works great. Perhaps a bad line is a cause of your problem.
If there is no fluid moving through the new line, try loosening the fittings between the master cylinder and the bleeder screw until you have an area that looses fluid when the pedal is pumped.
Old Jun 16, 2013 | 09:19 AM
terbear2910
I put the new lines up front....the problem was the bleeder screw it self...put a needle in top and bottom and tried again and it started working but thx for the help...idk wat it was but it works now...
ridecolby
49
Jan 14, 2019 04:31 AM
78fordranger
Nov 9, 2008 06:16 PM
quisp-n-quake
Oct 26, 2007 11:07 AM
PortlandDiesel
Nov 3, 2004 06:21 PM
84xplorer
May 6, 2002 01:05 PM
