Aerostar Ford Aerostar
Help
Old Jun 23, 2013 | 02:31 AM
Barreto Yanira's Avatar
Barreto Yanira
Help
Hello my name is Yanira and my 1997 Ford aerostar van lit the check engine light to take her to check and got p1443 and p0300 codes would help me to know that I can do and that parts or sensor that ...... ..
Old Jun 23, 2013 | 11:50 AM
KhanTyranitar's Avatar
KhanTyranitar
P1443 means you have a leak in the evaporative emissions system. To fix this, you need to inspect and replace any dry rotted rubber lines in the evap system leading to the purge canister (underneath the air filter box). Any faulty lines need to be replaced with hose that is rated for evaporative emissions, otherwise the gas fumes will rot the rubber and you will be back to the same problem. There is a solenoid that opens to allow the gas fumes to enter the engine during operation. If this solenoid isn't working, or is leaking, it will need to be replaced. There are also some rubber lines that connect the EVAP system to the gas tank, any of which could be broken or missing. Replace as needed. If the gas cap itself is left off, is leaking, or missing, it will also set this code.
As far as 300 series codes, they indicate that misfires are occuring. Misfires can be due to a lot of things, so diagnositcs are going to be required, there is no fix all for codes of that class. You need to start with the basics.
Remove and label the spark plugs one at a time. Compare their appearances to see if they tell a story about why the vehicle is running the way it does. Plugs that aren't firing or are weak will be fouled with fuel and oil. Rich cylinders or cylinders with oil leaking will be black with soot. Pay close attention to the cylinders that are worst.
Since misfires can come from so many causes, you will likely need to run a leakdown test. Cylinders that have good compression will pass the test. The reason for the leakdown test is that these engines have problems with exhaust seat wear, particularly when the engines are exposed to lean conditions that elevate the combustion temps. A leakdown test is a way to find out if this has occurred.
If an exhaust valve is not seating, the cause needs to be identified. Often it is due to vacuum leaks (evap codes are often vacuum leaks). When having this issue repaired, the cylinder heads must be removed. Once removed, the cylinder head needs to have the damaged exhaust seats replaced with much stronger ones. Often for the cost involved new heads can be more cost effective so long as they come with upgraded exhaust seats already installed, otherwise you old ones are more cost effective. The machine shop will then resurface the head to ensure it is flat. The heads must be reinstalled with a new head gasket and new head bolts, the old bolts cannot be reused. The head must be torqued properly or it will warp and develop head gasket leaks.
I think you need to access the health of the engine, and then decide if it is worth repairing. If you prefer, you can choose not to diagnose and instead replace the wires and plugs with OE grade (Autolite, Motorcraft, Magnacore, or NGK parts only, no other brands work). the problem with this approach is that it will only fix the issue if the ignition system is the cause of your misfires. This stuff probably needs to be done anyway, so you wont be out to much if you go ahead and do it anyway, but if other problems are the cause, and you are not willing to fix the other problems, you money on tune up items has been wasted.
Old Jun 23, 2013 | 11:53 PM
Barreto Yanira
Smile
Thank you for your explanation and support helped me enough to check and get right to the problem and that touches me inspection this week was a pleasure to be is the next
ocsnakeremoval
1983 - 2012 Ranger & B-Series
27
Nov 26, 2024 09:52 PM
Black Ford XLT
1978 - 1996 Big Bronco
Jun 30, 2013 06:47 AM
stuporman
Feb 1, 2011 12:33 PM
ieagreg1
Aug 29, 2006 12:59 PM
dallas lewis
Feb 25, 2006 11:40 PM
