E4OD rebuild problems
Old Jun 14, 2013 | 11:51 AM
Stevo-x's Avatar
Stevo-x
Hi all. I've been rebuilding my e4od tranny and I've run into a few problems. I test drove my truck afterward and it didn't like shifting gears. From first to second it would rev hi( 3,000+). Then it would feel like I slammed on the brake, then( after a rough and loud CLUNK!) it would finally shift. Never tested beyond that. Drove it home and proceeded to figure out what was wrong. My father, who went to school on auto trannys long ago, and who has opened said tranny a few times, was thinking it could be a check ball or the reverse/low one way sprag is in backwards. I checked the line pressure and it was too high( I know why, and am going to fix it.). I just need to know if that could be the problem, or if I should look for something else that is wrong. I installed a "superior transmissions" shift correction kit and misplaced a spring. The one way sprag being in backwards would be an idiot move bellow my experience, but I also can't afford let my pride get in my way. I'd like it to the check ***** or the high pressure so I don't have to tear the tranny down completely, but I'm also willing to do what is necessary to get her running properly again. Please help.
Old Jun 28, 2013 | 10:12 PM
Encho's Avatar
Encho
The Southernmost Mod
Hi Stevo, here you won't find much help, post here and you'll reach those who own the E4OD like you: https://www.ford-trucks.com/forums/forum28/
Btw, check the link in my signature, I also messed with my E4OD with more success, you might find useful info there.
Welcome to FTE!.
Old Jun 30, 2013 | 09:49 AM
Stevo-x's Avatar
Stevo-x
thank you for the link, and also the welcome. I've been reading posts for a while, looking for ideas on how to make my truck better. :-)
Old Jun 30, 2013 | 09:54 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You may have better luck with a transmission specific question in the Transmission forum CLICK HERE.
Old Jul 1, 2013 | 10:02 AM
glruff's Avatar
glruff
FTE Leadership Emeritus
Moved to transmission forum.
Old Jul 1, 2013 | 10:45 AM
Mark Kovalsky
I've seen this before. It was the low/reverse sprag installed backwards. When that truck did the 1-2 shift the rear wheels locked up.
oregon250
566
Sep 23, 2019 03:57 PM
breno1987
Aug 9, 2011 09:44 PM
brownbronco
Nov 18, 2008 07:03 PM
optikal illushun
Dec 8, 2003 05:30 PM
78ford100
Jan 21, 2003 12:00 AM
