Air Gap
Old Jun 7, 2013 | 03:49 PM
Awmjr05's Avatar
Awmjr05
Air Gap
Trying to remove the AC clutch plate to close up some of the air gap I have. What is the trick to keep the compressor from spinning and removing the 8mm bolt in the front of the compressor. I have tried turning the key on and turning the AC on trying to lock the compressor that way. But that is not engaging the compressor. Any ideas?
Old Jun 7, 2013 | 04:38 PM
dannyboy950's Avatar
dannyboy950
There is a special tool that will hold the clutch disk still then break loose the bolt with a 3/8 impact useually works.
Old Jun 7, 2013 | 07:51 PM
Mich6.0's Avatar
Mich6.0
use a 3/8 air-box gun and you will just have to watch the nut come off, then you will need a clutch puller to remove the clutch
Old Jun 7, 2013 | 09:50 PM
Yahiko's Avatar
Yahiko
When I get home I will post a photo of the tool
with some measurements.
Sean
gofast51004
Nov 24, 2009 07:56 PM
masseysbronco
1978 - 1996 Big Bronco
15
Aug 25, 2006 08:45 AM
1990aerostar
Aerostar
Jul 30, 2006 12:04 PM
Supershark
Jan 31, 2006 07:21 AM
YingxYang
Aerostar
Dec 18, 2003 07:47 PM
