EOD4 trans
Old Jun 1, 2013 | 01:43 PM
fuzz710's Avatar
fuzz710
EOD4 trans
I have a 1997 f250XL heavy duty (8,600Lbs)4x4 with 460 auto.the trans took a dump an a few of the shops say its a 97 only trans is this true? Or could I use one from another year?
Old Jun 1, 2013 | 02:38 PM
khadma's Avatar
khadma
Carpenter Local 745
Take your truck to another shop. Is there a reason why the transmission
Can't be rebuilt?
Old Jun 1, 2013 | 02:55 PM
fuzz710's Avatar
fuzz710
Well I did an got prices from 2900.00 plus 1000 core charge but they will have to tear it apart to see if it can be rebuilt, to 4000 cause its a one year only! That's why I'm trying to find out if its true. I did find one shop that only works on big rigs but since its over 8600 lbs he said 2000 which isn't bad an had a warranty 3 years 100,000 miles. Just got to get it towed bout 150 miles. Just tired getting jerked around even FORD wouldn't give me any info on the truck,an it was bought new in sept,97 so the motor/trans have never been out of truck an there telling me its a 5 speed manual! So been trying to find someone that's not going to tell you one starting to get to me.
Old Jun 1, 2013 | 03:32 PM
Lead Head's Avatar
Lead Head
They changed the solenoid connector for the '95 model year but all 460 95-97 E4ODs will interchange just fine.
The shop is technically right in that the '97 E4OD was a single year transmission. The 97 contained many upgrades over the 96 which had some upgrades over the 95 which was tremendously updated compared to the 94 and earlier E4ODs.
However, all the '97 specific parts can be installed into the earlier transmission. Many of the parts have completely superseded the older parts.
Old Jun 1, 2013 | 04:47 PM
rla2005's Avatar
rla2005
The obvious question is why do you think the transmission took a "dump"? The transmission is 100% electronic controlled, check for codes before tossing in the towel for a rebuild.
More than once someone on this forum has had their E4OD rebuilt to then find out they have the same problem. Of course if the transmission is puking out fluid or grinding you do have a serious problem.
Old Jun 2, 2013 | 08:33 AM
fuzz710's Avatar
fuzz710
The reason I think it took a dump is it stop working smells burnt an when I pulled pan it was full of metal shavings not now it just grinds!
Old Jun 2, 2013 | 08:40 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
keep calling around.you'll find a reputable trans shop.you want someone with good experience with the e40d to build it properly.when you find the right guy,he'll know what to do to any year e40d without making a fuss about it being a '97.
daveengelson
17
Mar 4, 2013 07:49 PM
cfpinz
Ford Truck Parts for Sale
Jul 16, 2012 09:28 AM
yfz 450
18
May 22, 2012 02:20 PM
kpmurfy15
Oct 26, 2008 07:09 PM
kurt97F150
1997 - 2003 F150
Apr 23, 2007 07:15 AM
