Brighter Backup Lights - Help Please
Old Jun 1, 2013 | 07:37 PM
PITS's Avatar
PITS
Home - M & R Automotive has the neatest little 10W single LED foglights that mount easily to your bumper and run to a upfitter. I use them to "supplement" my factory (crap) backup lights.
Some pics:
Old Jun 3, 2013 | 11:36 PM
Chad149's Avatar
Chad149
https://www.ford-trucks.com/forums/1...-lights-2.html
Here is a link to a reverse light install from the F-150 forum. Used some Rigid lights that might work better with a little fab work, as I think your holes are a bit bigger.
Old Jun 4, 2013 | 11:07 AM
CornTruckDriver's Avatar
CornTruckDriver
Originally Posted by kper05
Yeah but they're nice, although mine aren't LED.
They look like mine from NAPA. I have 4 of them. started with 2 but wanted a wider spread. They are hooked to an up-fitter. There good for seeing at night with mirrors but you can actually see better with the back up cam with them off. Much better. Bright spots screw up the camera.
Old Jul 11, 2013 | 01:10 AM
LaxPlaya21's Avatar
LaxPlaya21
Depending on what your budget is, you can get crazy. Baja designs makes the best LED lights on the market. Aside from being the best light, it's more about the versatility of their products. I plan on using Baja Designs SII flush mount fixture on my next truck in the rear bumper. These come with a flush mount plate.
I plan on replacing my fogs with Baja Designs Squadrons.
And lastly if I'm not broke... A Baja Designs OnX light bar?
The OnX on my bike
The reason I like these lights the best is that the little reflectors can be swapped out easlily between spot, driving and flood. And you can combo whatever you suits your needs. You can also replace the outter lens with orange, blue, red, green... Or diffuser. The OnX also has a strobe mode.
These are top of the line LEDs with the price to match it. But to me lighting is everything.
Old Jul 11, 2013 | 04:15 AM
Gunny77's Avatar
Gunny77
I have the same ranch hand bumper with lights and was thinking about upgrading as well.
Take a look at etrailer
Sealed, 6-1/2" Oval LED Trailer Utility Light, Flange Mount, 10 Super Diode - Clear Optronics Trailer Lights BUL78CB
I also considered replacing the stock truck backup lights with LED bulbs and replacing the bumper lights with red LEDs tied to the brake lights for added visibility.
Old Jul 11, 2013 | 08:43 AM
Byram's Avatar
Byram
Yea - those look good - might give them a try..
Old Jul 11, 2013 | 10:29 AM
ggadwa's Avatar
ggadwa
Brighter Reverse Lights
I f you want a great System go to:
White Night Rear Lighting System, Truck SUV Reverse Lights
These require that you put their dual Halogen lights on your Hitch Stinger. It is wired directly to reverse and also has a separate switch so you can turn them on for working at the rear of you vehicle without being in Reverse.
I had them on my 2000 F-250SD and when I sold the truck this past winter I left them on it as the new buyer really liked them too.
I have yet to get the White Night kit for my 2012 F-350 but I plan to.
GARY
Old Jul 11, 2013 | 10:52 AM
ggadwa's Avatar
ggadwa
Bummer... I just called White Night Backup Lights folks and they say they do not have mold that fits over the 2 and 1/2 Hitch on my F350 Heavy Duty Hitch. They have everything you need for the Standard 2 inch Hitch and Stinger. The Units are even On Sale.
GARY
Old Jul 11, 2013 | 12:32 PM
majkthreads's Avatar
majkthreads
I did rigid cube lights on the back mounted under the bumper. Then wired to a rocker switch. I can turn them off and on as I please.
Where it helps is not necessarily backing up as the 2012 back up cameras are pretty good at night. But it works best when I'm physically hooking up the trailer. No need for a flashlight, I can just work on hooking everything up with nice bright light.
Old Jul 11, 2013 | 08:50 PM
army350's Avatar
army350
kper05, it looks like I have the same lights as you and I have them hooked into Aux 2 as well. I like them a lot and they were easy to install.
joninflorida
Feb 14, 2019 12:52 PM
410F-100
Aug 27, 2012 02:53 AM
slowmans
May 13, 2009 05:49 PM
DORF100
Dec 7, 2006 03:23 PM
eigenvector
1983 - 2012 Ranger & B-Series
Mar 6, 2004 02:26 AM
