P1212 code
Old May 29, 2013 | 09:24 PM
Dirtboy953b's Avatar
Dirtboy953b
P1212 code
Hello all!, I've got a 2000 year model 7.3,and it's been hard to start the last few weeks,put everything new for the glow plugs in it and its still hard to start,well now it won't start at all and I'm getting a p1212 code. The truck has a little over 250k+ on it. Any help would be great! Thanks!
Old May 29, 2013 | 09:56 PM
tappit01's Avatar
tappit01
i would check the icp "injector control pressure" sensor see if it has oil in the electrical plug. try to start it up with it unplugged . its located in the drivers side head up at the front. maybe some one can post up a pic for you , i dont have one handy.
Old May 29, 2013 | 10:29 PM
Dirtboy953b
I did check it and it looked dry,ill check again,I'll try starting it with it in plugged in the morning.
Old May 30, 2013 | 12:12 AM
cjgray1974's Avatar
cjgray1974
I'd also check the IPR and make sure the nut on the back is tight.
Old May 30, 2013 | 07:35 AM
Tugly's Avatar
Tugly
Remove the connector from the ICP and see if it starts. Make sure your oil is up to the mark.
Old Jun 1, 2013 | 12:16 PM
Dirtboy953b
Ok I got a chance to mess with it,the IPR is tight,the ICP has a little oil in the plug,I up plugged it and it did not fire.
Old Jun 5, 2013 | 11:27 AM
Dirtboy953b
Still no luck.....
Old Jun 5, 2013 | 01:06 PM
Stewart_H's Avatar
Stewart_H
With everything you've done, and the problem being a 1212 code you probably need a new IPR. But I'd hate for you to start throwing parts at it, so wait until others chime in to try and help you eliminate other possibilities that cost less than a brand new IPR.
Stewart
EDIT: Custom tunes/chip or stock programming?
Old Jun 5, 2013 | 01:08 PM
Tugly's Avatar
Tugly
The injector troubleshooting link in my signature may be of use with this one.
Old Jun 5, 2013 | 01:15 PM
Stewart_H's Avatar
Stewart_H
Check the wiring for the IPR too. Make sure the insulation isn't chaffed.
Stewart
clintusaf
19
Jun 16, 2014 09:29 PM
PJ-Hunter
May 13, 2013 06:39 AM
tjbjeepn
Jan 22, 2013 10:42 AM
BuddyB
Nov 10, 2011 10:21 AM
BodegaErik
Jul 2, 2006 10:20 PM
