Auto trans linkage
Old May 29, 2013 | 06:56 PM
264WSM's Avatar
264WSM
Auto trans linkage
I don't deal w/ automatics but my Dad's '95 F-150 is having some issues.
When you pull the selector level it feels mushy and sometimes says "N" when you are in drive. Other times it says "D" and you are in second. Recently he put in "P", got out and the truck started rolling!! Finding reverse takes 2-3 tries to miss N and P.
What linkage needs to be adjusted/replaced to solve this?? Is it at the trans or up on the steering column?? The truck doesn't have a tach, but I can tell going down the road that something is not right. However, my 79 y.o. father is in "highway bliss" and doesn't realize he is in second gear at 55mph
Old May 29, 2013 | 07:08 PM
White 97 xlt's Avatar
White 97 xlt
There are two bolts that work loose under the dash on the lower end of the shifter, they are torx.... When these work loose shifting can be hit or miss for sure.. There are pictures of the bolts in question floating around here somewhere, maybe someone will chime in who know where the picture is and post it..
Old May 29, 2013 | 07:28 PM
rla2005's Avatar
rla2005
Courtesy of subford
Old May 29, 2013 | 07:48 PM
White 97 xlt
Thanks!!!..............
Old May 30, 2013 | 08:23 AM
264WSM's Avatar
264WSM
Can I access these T-30 bolts w/o removing the bottom half of the dash/ steering column?? I'm not a contortionist but if it saves me 4 hours of work I'll try to be one!!
Old May 30, 2013 | 09:42 AM
White 97 xlt
Yes, the bolts are just above the brake pedal, and can be seen by laying in the floor...
You don't need to be a contortionist, but rubber arms might be a help!!
Old May 30, 2013 | 10:32 AM
Encho's Avatar
Encho
The Southernmost Mod
If you tighten those and the problem remains, you need to replace the shifter cable, and believe me, you don't want to hold that one off, if you keep driving with a stretched cable you'll break the shifter tube and then it will become a whole new problem. It happened to me and it sucked... And the tube is around $40, just to add to the aggravation...
Old Jun 17, 2013 | 07:54 AM
264WSM's Avatar
264WSM
The 2 bolts were the problem - THANX a bunch.
The same shop that raped my dad on the injectors wanted $300 to fix this. You guys had me go in there with the correct tools and I was done in 3 minutes.
Sounds like I owe somebody a beer
Old Jun 17, 2013 | 08:31 AM
Encho's Avatar
Encho
I'm glad you found the cause and that it was the easiest fix. It was good of you to report back.
Encho
65
Oct 27, 2012 02:28 PM
tealcheif
Aug 13, 2011 01:37 PM
fordguy76
General Automotive Discussion
Dec 24, 2007 07:01 PM
cooploops
Oct 27, 2007 02:43 PM
fatforty
Apr 10, 2001 11:51 AM
