worn out shifter
Old Aug 12, 2011 | 08:17 PM
tealcheif's Avatar
tealcheif
worn out shifter
i have a 95 f250 4x4 w/5.8 .w/ 198k mi. and an automatic trans. my problem is, when i shift into drive from park or reverse to drive the trans goes into 2nd gear instead of drive most of the time.(which is very annoying!) is the problem in the steering column? how hard is it too fix? i don't mind pulling the steering wheel if i know that is where the problem is, and i know what i'm getting into. i have already tried moving the adjustment underneath the cab, but it made no difference. i would appreciate any info on this problem . thank you!!
Old Aug 13, 2011 | 07:20 AM
Lazy K's Avatar
Lazy K
If you look at the bottom of the steering column you should see a "lever" with two torx head bolts, check that these bolts are tight.
Old Aug 13, 2011 | 12:28 PM
tealcheif's Avatar
tealcheif
THANK YOU! I WILL!!
Old Aug 13, 2011 | 01:19 PM
tealcheif's Avatar
tealcheif
that was it! it took a whole 3 min. to fix. they were about to fall out! THANK YOU VERY MUCH!! ( i wish i would have asked 2 yrs ago!)
Old Aug 13, 2011 | 01:37 PM
Lazy K's Avatar
Lazy K
You are more than welcome. Good luck.
randy06
Modular V10 (6.8l)
24
Sep 12, 2019 04:58 AM
dmueller71
Mar 31, 2015 08:18 AM
esmarkey
May 30, 2013 07:33 PM
pimmy69
Sep 3, 2010 07:43 PM
76supercab2
May 18, 2005 10:34 AM
