General Automotive Discussion
'94 Crown Vic trans question
Old Dec 19, 2007 | 04:23 PM
fordguy76's Avatar
fordguy76
My girlfriends dad has a '94 crown vic with a 4.6 V8 and an overdrive auto, he drove it home one day and parked it, then when he went to leave again it wouldn't go anywhere, forward or reverse. I looked at it hoping it was the column, since it did not click into any gears but after partially dismantling the dash I saw nothing obviously broke. So then I checked the cable to the trans and it isn't broken then I shifted the trans by hand under the car and it felt good, however, it rolls in every gear. So I assume the trans is toast? Is that a fair assumption? I just don't see how the column being connected to the trans still by the cable won't move the arm on the transmission?
Old Dec 19, 2007 | 04:29 PM
Bart99GT's Avatar
Bart99GT
An automatic will roll if its in any gear but park without the engine running. There's no solid connection between the engine and transmission with an auto.
My guess is that there's probably a roll pin broken somewhere in the column. It might not be immediately obvious until you take the entire shift mechanism apart.
Old Dec 19, 2007 | 07:42 PM
GLR's Avatar
GLR
With the CV's you have to step on the brake in order to put it in gear. Maybe it got forced causing linkage problems. The AODE trans is usually pretty good. Can you jack it up (JACK STANDS) and look underneath while someone works the shifter. That will tell you if linkage is working.
Old Dec 22, 2007 | 11:54 PM
fordguy76's Avatar
fordguy76
"With the CV's you have to step on the brake in order to put it in gear. Maybe it got forced causing linkage problems. The AODE trans is usually pretty good. Can you jack it up (JACK STANDS) and look underneath while someone works the shifter. That will tell you if linkage is working."---------------What are CV's? Well I crawled under the car and shifted the trans and had someone hold the shifter and I couldn't shift then so the cable is definitely good, it must be in the column somewhere, now it won't start either, I'm guessing some type of neutral saftey switch on the column?
Old Dec 23, 2007 | 10:25 AM
lsrx101's Avatar
lsrx101
The neutral safety switch is on the transmission. If the cable is not pulling the manual lever into Park or Neutral the car won't start.
A very common issue on these cars is with the shift tube on the steering column. The shifter "stick" is connected to a tube that runs down the column and is connected to the shift cable. The tube is clamped to the column with 2 U-clamps. The bolts work loose on the clamps and let the tube move instead of moving the cable.
The cable sheath is also supported by a bracket on the column. The bracket can work loose or the cable can pop out of the bracket.
I've seen all 3 happen, but the loose U-clamps are the most common.If the cable has pulled out of the support bracket, it usually means the cable is binding internally and needs replaced.
Old Dec 23, 2007 | 02:34 PM
fordguy76's Avatar
fordguy76
thanks, i knew that old 3spd autos had the neutral safety switch on the trans and thought he maybe they put it on the column on these.
Old Dec 23, 2007 | 02:44 PM
lsrx101's Avatar
lsrx101
FYI, The NSS on an AOD\AODE looks different than the ones you may have seen on older 3 speed units. It threads into the case just behind the manual lever.
Old Dec 24, 2007 | 02:20 AM
fordguy76's Avatar
fordguy76
thanks, I'll check for bad u-clamps
Old Dec 24, 2007 | 07:01 PM
Mazlem's Avatar
Mazlem
what are CV's ? Why Crown Vics of course. As GM's are Grand Marquis.
jason8374
69
May 24, 2018 10:33 PM
slow2v
Jun 26, 2015 03:57 PM
demon53
Feb 6, 2015 12:47 AM
86f150lariat
Jul 21, 2014 07:17 AM
JRD2849
Aug 19, 2013 11:46 PM
